Hello guys, since last week I have all these errors and nothing works anymore.
I didn’t touch anything.
I tried to delete the DB file or restore a backup but no luck.
2024-03-07 12:20:28.187 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration ps4_custom which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-03-07 12:20:28.192 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-03-07 12:20:28.197 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration pun_sensor which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-03-07 12:20:28.202 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration candy which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-03-07 12:20:28.206 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-03-07 12:20:28.210 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration govee which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-03-07 12:21:08.761 WARNING (MainThread) [homeassistant.setup] Setup of tag is taking over 10 seconds.
2024-03-07 12:21:08.761 WARNING (MainThread) [homeassistant.setup] Setup of input_datetime is taking over 10 seconds.
2024-03-07 12:21:08.762 WARNING (MainThread) [homeassistant.setup] Setup of counter is taking over 10 seconds.
2024-03-07 12:21:08.762 WARNING (MainThread) [homeassistant.setup] Setup of input_number is taking over 10 seconds.
2024-03-07 12:21:08.763 WARNING (MainThread) [homeassistant.setup] Setup of schedule is taking over 10 seconds.
2024-03-07 12:21:10.208 WARNING (MainThread) [homeassistant.setup] Setup of smartthings is taking over 10 seconds.
2024-03-07 12:21:14.829 WARNING (MainThread) [homeassistant.setup] Setup of input_button is taking over 10 seconds.
2024-03-07 12:21:14.895 WARNING (MainThread) [homeassistant.setup] Setup of input_text is taking over 10 seconds.
2024-03-07 12:21:14.896 WARNING (MainThread) [homeassistant.setup] Setup of timer is taking over 10 seconds.
2024-03-07 12:21:15.336 ERROR (SyncWorker_8) [homeassistant.components.fritzbox_callmonitor.sensor] Cannot connect to 192.168.1.1 on port 1012: [Errno 111] Connection refused
2024-03-07 12:21:15.634 ERROR (MainThread) [metno] Access to https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned error 'ClientConnectorError'
2024-03-07 12:21:15.703 WARNING (MainThread) [homeassistant.setup] Setup of input_select is taking over 10 seconds.
2024-03-07 12:21:19.138 WARNING (MainThread) [homeassistant.components.media_player] Setup of media_player platform songpal is taking over 10 seconds.
2024-03-07 12:21:20.130 WARNING (MainThread) [homeassistant.components.songpal.media_player] [Soundbar(http://192.168.1.7:10000/sony)] Unable to connect
2024-03-07 12:21:20.175 ERROR (MainThread) [homeassistant.components.mqtt.client] Failed to connect to MQTT server due to exception: [Errno -3] Try again
2024-03-07 12:21:20.300 WARNING (MainThread) [homeassistant.components.media_player] Platform songpal not ready yet; Retrying in background in 30 seconds
2024-03-07 12:21:22.081 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Home Assistant Cloud for netatmo
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 504, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/netatmo/__init__.py", line 75, in async_setup_entry
await config_entry_oauth2_flow.async_get_config_entry_implementation(
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 421, in async_get_config_entry_implementation
raise ValueError("Implementation not available")
ValueError: Implementation not available
2024-03-07 12:21:24.084 WARNING (MainThread) [custom_components.pun_sensor] Errore durante l'aggiornamento via web, nuovo tentativo tra 1 minuto.
File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 1173, in _create_direct_connection
hosts = await asyncio.shield(host_resolved)
File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 884, in _resolve_host
addrs = await self._resolver.resolve(host, port, family=self._family)
File "/usr/local/lib/python3.12/site-packages/aiohttp/resolver.py", line 33, in resolve
infos = await self._loop.getaddrinfo(
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 899, in getaddrinfo
return await self.run_in_executor(
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.12/socket.py", line 963, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File "/config/custom_components/pun_sensor/__init__.py", line 292, in update_pun
await self._async_update_data()
File "/config/custom_components/pun_sensor/__init__.py", line 163, in _async_update_data
async with self.session.get(LOGIN_URL) as response:
File "/usr/local/lib/python3.12/site-packages/aiohttp/client.py", line 1194, in __aenter__
self._resp = await self._coro
File "/usr/local/lib/python3.12/site-packages/aiohttp/client.py", line 578, in _request
conn = await self._connector.connect(
File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 544, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 911, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 1187, in _create_direct_connection
raise ClientConnectorError(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host www.mercatoelettrico.org:443 ssl:default [Try again]
2024-03-07 12:21:25.166 ERROR (MainThread) [custom_components.hacs] Request exception for 'https://api.github.com/rate_limit' with - Cannot connect to host api.github.com:443 ssl:default [Try again]
File "/config/custom_components/hacs/base.py", line 464, in async_can_update
response = await self.async_github_api_method(self.githubapi.rate_limit)
File "/config/custom_components/hacs/base.py", line 522, in async_github_api_method
raise HacsException(_exception)
custom_components.hacs.exceptions.HacsException: Request exception for 'https://api.github.com/rate_limit' with - Cannot connect to host api.github.com:443 ssl:default [Try again]
2024-03-07 12:21:25.223 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'hacs' accesses hass.components.frontend. This is deprecated and will stop working in Home Assistant 2024.9, it should be updated to import functions used from frontend directly at custom_components/hacs/frontend.py, line 58: hass.components.frontend.async_register_built_in_panel(, please create a bug report at https://github.com/hacs/integration/issues
2024-03-07 12:21:45.638 WARNING (MainThread) [homeassistant.components.ps4.media_player] PS4 could not be reached
2024-03-07 12:22:27.833 ERROR (SyncWorker_1) [homeassistant.util.package] Unable to install package govee-api-laggat==0.2.2: WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa1f5c2c0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/govee-api-laggat/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa16ec440>: Failed to establish a new connection: [Errno -3] Try again')': /simple/govee-api-laggat/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa124c770>: Failed to establish a new connection: [Errno -3] Try again')': /simple/govee-api-laggat/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa124c980>: Failed to establish a new connection: [Errno -3] Try again')': /simple/govee-api-laggat/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa13a7f80>: Failed to establish a new connection: [Errno -3] Try again')': /simple/govee-api-laggat/
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa124c8f0>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux-index/govee-api-laggat/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa124ce60>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux-index/govee-api-laggat/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa124d070>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux-index/govee-api-laggat/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa124d280>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux-index/govee-api-laggat/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa124d4f0>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux-index/govee-api-laggat/
ERROR: Could not find a version that satisfies the requirement govee-api-laggat==0.2.2 (from versions: none)
ERROR: No matching distribution found for govee-api-laggat==0.2.2
2024-03-07 12:22:29.165 WARNING (MainThread) [custom_components.pun_sensor] Errore durante l'aggiornamento via web, nuovo tentativo tra 10 minuti.
