I’m running HassOS on a VM with a Aeotec ZW090 Z-Stick Gen5.
Today I upgraded from 0.85.0 to 0.85.1.
Now I got tons of zwave warnings in the log and the nodes don’t leave “initializing” state.
The devices do not work at all or very slow.
Please Help
This is the log
2019-01-14 01:17:32 WARNING (Dummy-29) [openzwave] Z-Wave Notification ValueChanged ({'homeId': 4064515364, 'nodeId': 21, 'commandClass': 'COMMAND_CLASS_METER', 'instance': 1, 'index': 32, 'id': 72057594395263488, 'genre': 'User', 'type': 'Bool', 'value': False, 'label': 'Exporting', 'units': '', 'readOnly': True}) for an unknown node 21
2019-01-14 01:17:32 WARNING (Dummy-29) [openzwave] Z-Wave Notification ValueChanged ({'homeId': 4064515364, 'nodeId': 21, 'commandClass': 'COMMAND_CLASS_METER', 'instance': 1, 'index': 20, 'id': 72057594395263298, 'genre': 'User', 'type': 'Decimal', 'value': 0.0, 'label': 'Current', 'units': 'A', 'readOnly': True}) for an unknown node 21
2019-01-14 01:17:32 WARNING (Dummy-29) [openzwave] Z-Wave Notification ValueChanged ({'homeId': 4064515364, 'nodeId': 21, 'commandClass': 'COMMAND_CLASS_METER', 'instance': 1, 'index': 21, 'id': 72057594395263314, 'genre': 'User', 'type': 'Decimal', 'value': 0.0, 'label': 'Previous Reading', 'units': 'A', 'readOnly': True}) for an unknown node 21
2019-01-14 01:17:32 WARNING (Dummy-29) [openzwave] Z-Wave Notification ValueChanged ({'homeId': 4064515364, 'nodeId': 21, 'commandClass': 'COMMAND_CLASS_METER', 'instance': 1, 'index': 22, 'id': 72057594395263331, 'genre': 'User', 'type': 'Int', 'value': 301, 'label': 'Interval', 'units': 'seconds', 'readOnly': True}) for an unknown node 21
2019-01-14 01:17:49 WARNING (Dummy-29) [openzwave] Z-Wave Notification ValueChanged ({'homeId': 4064515364, 'nodeId': 4, 'commandClass': 'COMMAND_CLASS_SENSOR_MULTILEVEL', 'instance': 1, 'index': 3, 'id': 72057594110033970, 'genre': 'User', 'type': 'Decimal', 'value': 0.0, 'label': 'Luminance', 'units': 'lux', 'readOnly': True}) for an unknown node 4
2019-01-14 01:17:50 ERROR (SyncWorker_3) [homeassistant.components.switch.command_line] Command failed: python3 /config/python_scripts/twinkly.py 192.168.2.101 state
2019-01-14 01:17:53 WARNING (Dummy-29) [openzwave] Z-Wave Notification ValueChanged ({'homeId': 4064515364, 'nodeId': 14, 'commandClass': 'COMMAND_CLASS_METER', 'instance': 1, 'index': 32, 'id': 72057594277822976, 'genre': 'User', 'type': 'Bool', 'value': False, 'label': 'Exporting', 'units': '', 'readOnly': True}) for an unknown node 14
2019-01-14 01:17:53 WARNING (Dummy-29) [openzwave] Z-Wave Notification ValueChanged ({'homeId': 4064515364, 'nodeId': 14, 'commandClass': 'COMMAND_CLASS_METER', 'instance': 1, 'index': 0, 'id': 72057594277822466, 'genre': 'User', 'type': 'Decimal', 'value': 11.105999946594238, 'label': 'Energy', 'units': 'kWh', 'readOnly': True}) for an unknown node 14
2019-01-14 01:17:53 WARNING (Dummy-29) [openzwave] Z-Wave Notification ValueChanged ({'homeId': 4064515364, 'nodeId': 14, 'commandClass': 'COMMAND_CLASS_METER', 'instance': 1, 'index': 1, 'id': 72057594277822482, 'genre': 'User', 'type': 'Decimal', 'value': 11.105999946594238, 'label': 'Previous Reading', 'units': 'kWh', 'readOnly': True}) for an unknown node 14
2019-01-14 01:17:53 WARNING (Dummy-29) [openzwave] Z-Wave Notification ValueChanged ({'homeId': 4064515364, 'nodeId': 14, 'commandClass': 'COMMAND_CLASS_METER', 'instance': 1, 'index': 2, 'id': 72057594277822499, 'genre': 'User', 'type': 'Int', 'value': 300, 'label': 'Interval', 'units': 'seconds', 'readOnly': True}) for an unknown node 14
2019-01-14 01:17:53 WARNING (Dummy-29) [openzwave] Z-Wave Notification ValueChanged ({'homeId': 4064515364, 'nodeId': 14, 'commandClass': 'COMMAND_CLASS_METER', 'instance': 1, 'index': 8, 'id': 72057594277822594, 'genre': 'User', 'type': 'Decimal', 'value': 0.0, 'label': 'Power', 'units': 'W', 'readOnly': True}) for an unknown node 14
Edit:
And my CPU usage goes up to 40% (from 3% Idle)
