Toon Climate - change the GUI
I’m using Home Assistant 2022.11.5 and I am trying to add a custom template for my rooted Toon (Eneco) like:
github: cyberjunky/home-assistant-toon_climate
I already installed HACS and I have installed the “Toon Climate” integration. My Toon thermostat is now added to the dashboard and looks like:
HA-toon
I can adjust the temperature within HA without any issues. But now I want to implement the layout as described at:
Now I get lost… The part of this page that starts with “Toon with simple-thermostat in Lovelace” is something I don’t understand.
What and where can I perform this step:
Install Javascript from: GitHub - nervetattoo/simple-thermostat: A different take on the thermostat card for Home Assistant ♨️
And where can I add the codes to change the card? Can someone please guide me a little around to get this done?
I don’t know if this issue still is relevant for you, but here’s to sollution for other people who came across the same issue:
  • Install Simple Thermostat via HACS
  • Add the following to resources:
url: /hacsfiles/simple-thermostat/simple-thermostat.js
type: module
Now go to your dashboard and change the current yaml into
- type: 'custom:simple-thermostat'
     entity: <device name of your toon>
     control:
       - preset
This is what did the trick for me.
Bonus suggestion:
Hide everything but sensors and temperature control:
- type: custom:simple-thermostat
layout:
  step: row
header: false
control: false
