I have a rooted Toon1, with the latest update. But I get error with the install of TOON Climate via HACS. What am I doing wrong? Do I have to check something on TOON itself?
climate:
- platform: toon_climate
name: TOON Thermostat
host: 192.168.123.9
port: 10080
scan_interval: 10
Logboekdetails ( ERROR )
Sat Jan 04 2020 16:43:40 GMT+0100 (Midden-Europese standaardtijd)
Error while setting up platform toon_climate
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 157, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 84, in create_connection
raise err
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 74, in create_connection
sock.connect(sa)
socket.timeout: timed out
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 672, in urlopen
chunked=chunked,
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 387, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/local/lib/python3.7/http/client.py", line 1252, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/local/lib/python3.7/http/client.py", line 1298, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.7/http/client.py", line 1247, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.7/http/client.py", line 1026, in _send_output
self.send(msg)
File "/usr/local/lib/python3.7/http/client.py", line 966, in send
self.connect()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 184, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 164, in _new_conn
% (self.host, self.timeout),
urllib3.exceptions.ConnectTimeoutError: (<urllib3.connection.HTTPConnection object at 0x7fb0d9906b10>, 'Connection to 192.168.123.9 timed out. (connect timeout=5)')
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 720, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 436, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.123.9', port=10080): Max retries exceeded with url: /happ_thermstat?action=getThermostatInfo (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x7fb0d9906b10>, 'Connection to 192.168.123.9 timed out. (connect timeout=5)'))
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 150, in _async_setup_platform
await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 442, in wait_for
return fut.result()
File "/config/custom_components/toon_climate/climate.py", line 68, in setup_platform
config.get(CONF_PORT))])
File "/config/custom_components/toon_climate/climate.py", line 90, in __init__
self.update()
File "/config/custom_components/toon_climate/climate.py", line 119, in update
'/happ_thermstat?action=getThermostatInfo'))
File "/config/custom_components/toon_climate/climate.py", line 95, in do_api_request
req = requests.get(url, timeout=DEFAULT_TIMEOUT)
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 75, in get
return request('get', url, params=params, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 60, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 504, in send
raise ConnectTimeout(e, request=request)
requests.exceptions.ConnectTimeout: HTTPConnectionPool(host='192.168.123.9', port=10080): Max retries exceeded with url: /happ_thermstat?action=getThermostatInfo (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x7fb0d9906b10>, 'Connection to 192.168.123.9 timed out. (connect timeout=5)'))
