I’m upgrading my HA config and I was wondering: “is it possible to show the 10 most (manually operated) entities with automated updates in the main screen?”. I think I can count them (monitoring the event bus or MQTT communication) but how about displaying them? Let’s call it my epiphany after a few beers on a saturday night …
You could write an Automation (or maybe a Python Script) that took the counts you’ve measured and added the 10 entities to a group. Then just display the group in the front end.
Yes. There is a group.set service available. It’s not documented, it seems, in the Home Assistant docs. But if you go to the “Services” tab in “Developer Tools” you can select group.set and it will give you some details on how to use it.
I’ve never used it. But I learned about looking at someone else’s automation that handles adding low battery devices to a group for display. I’m not sure if you have to call group.reload after changing the group or if home assistant detects this on its own.
Either way, for this use case, I don’t think you’d bother to calculate the most used entities very often, so the extra time required to call group.reload shouldn’t be a problem.
that part i have covered 80% of all (manual) actions go through MQTT with a local domotics broker where the topic identifies if it is a push button on the wall, a input inside HA (MQTT) or automation. That way I know the difference … If I ever succeed in this wild idea, i will post the concept and the code. I think it will or nodered or pin ython …
