Top banner on IOS Transparent gray
Hello, I updated to 0.51.2 today and the top banner on my all my IOS devices have a light gray (usually blue) and all the sliders are transparent. This is on the app and web page in safari and chrome browsers I was on 0.49.1 It also happened when I updated to 0.50.0 but I went back to 0.49.1 I have a android device and its ok on it.
I have this on safari on my MBP but it works ok on iOS. Don’t know when it started as I updated to 51.1 on my pc and didn’t load HA on my mac until after I had updated to 51.2. Apologies for the screenshot but you can see the issue.
Can confirm that I cleared the cache on safari but there is no change.
I have the same but only on an old iPad which is in iOS 9
I don’t have the issue on my iPhone on ios10, nor new iPad on iOS 11
Not sure but there could be a wider issue going on here. Normally when I change my theme on say any browser or phone all change together - now I can change the theme on a browser and that changes but my phone is still on the previous theme. Restarting the browser on pc or phone and it doesn’t change to the new theme.
If I change a switch setting or a temperature change occurs that changes on all devices so it’s just affecting the visuals of HA
All my IOS devices are iOS9, also had some trouble with some of my intents this morning so went back to 0.49.1
It’s maybe a problem with migration to polymer2. Older, not updated browser is a problem.
OK I updated to 0.53.0 today and still having the problem with the transparent gray and sliders. All my IOS devices are iOS9 and I Can’t update.
So I’m I just out of luck because I have IOS 9?
The app has the same problem. So I had to go back to 0.49.1
did you find any alternative ? I m also stuck with Ipad 2 …
@Matthieu_Tourlouse no we are stuck on 0.49.1 We would have to buy new devices if we want to see the pages properly.
Try using the Chrome browser - it works for me on my iPad 3 where the iOS App and Safari do not. You cannot save as a shortcut but to see and use HA it works fine for me using Chrome.
Yep Ipad3 are running on ios10 which is fine. but not ipad2 :confused:
iPad 3 runs iOS 9.3.5 so will not be supported in the IOS app and safari has issues running it as well. Chrome is the best option so far.
