Top header color
I have just updated to latest beta 2.0 and now I see different color of top header:
I am using default theme with only one change - device tracking color.
Is this ok, and I just have to write one more thing in themes.yaml or something went wrong?
Here is old app
I believe the header color is called primary-color in themes.yaml.
Just don’t use opacity in the header as the top part will stay white. Also a hard close of the app and restart might fix the problem. (Or try the new frontend cache clear button in the settings of the mobile app, and restart the app afterwards).
Actually I did change “primary-color: ‘#04a8f4’” and now I have everything looking fine
But It should not be that way in a first place
It shouldn’t no, that is why I mentioned to close the app and restart it, as that works 9 out of 10 times. (but make sure the app is hard closed). Or the brand new clear cache button in the mobile app settings (at the bottom).
Anyways great that it worked!
