Just to add, i created the new view and then scrolled down to the bottom of the dashboard code and added it there. Im baffled why I cant just add the url in the view options. Am I not understanding something?
I have another view called temp in a dashboard called home-devices. The url I would have to type into to the browser to go directly there is http://homeassistant.home:8123/home-devices/temp
Thank you , tried all sorts of combinations and nothing works . If you put in a path within the same dashboard it then locks you out of the ability to edit that view so I then have to remove the code and loose that view.
To be honest I have given up as what should be a simple config as wasted so much time… but thank you for trying to help
As soon as I add this , the view link becomes un-editable then and I have to remove that code from the whole dashboard code
I tried your code as well but because there is no card I don’t understand how that can work… When I create new view there is an option for a url but that doesnt work… I’m confused now which is why I gave up
Hi , to make it easy I created a new dashboard called test with a couple of cards for date & time and weather. I then created a new view with the url to the other view in the mobile dashboard. Didnt work and in fact caused the problem when now I cannot edit the downstairs view unless I edit via yaml.
Aren’t you trying to navigate to Downstairs from view Test
Are both the views in dashboard dashboard-mobile?
By ‘Top Menu’, do you mean badges or do you want to create your own menu (in which case we can talk about how to do that).
If you do mean badges and are trying to link within the same dashboard, you don’t need to specify the dashboard so, for example, to link from Test to Downstairs, try this:
Yeh basically , I have a default dashboard called mobile.
This as 4 views called
Home - Main dashboard designed for mobile use via app
Car - View of tesla and various parameters via the Tessie integration
Downstairs - a plan of the downstairs of the house with all the devices on
Upstairs - same as downstairs but the upstairs level
Then i have another dashboard called …wait for it Dashboards ( i know took me ages to think of that one) which is designed more for a tablet layout and as 3 views, which are
Main - Random sensors , date/time , button to switch helpers etc
Hallway - Again designed for Hallway tablet with links to show London Underground tube status etc
Home Engery - shows energy usage from Hildebrand Glow integration with house smart meters
What I was trying to do was have another view on the Dashboard (Dashboard) that displayed the Downstairs view from the mobile dashboard. This way I only have the one downstairs dashboard and don’t have to maintain two give it uses the picture-elements card with round 50 sensors, lights, smart plugs etc shown on it.
I thought because the downstairs dashboard gave me a url in a browser of
/dashboard-mobile/house-layout I just just input that in the view url of the other dashboard to link to it… But sadly not .
looking on the community I think this as been asked for as a feature so the only way I can do it for now is a button on one of the existing views like I do now for the mobile view to display devices/batteries etc
Shame it cannot be done but a button instead is not a great shake really i guess
The boxes in red are the same single decluttering-card but called from 2 different dashboards/views. The card itself is a mix of custom:vertical-stack-in-card, custom:button-card, and conditional-card.
You can pass variables such that every button (outside of the red square) that you see in the first screen is in fact only one of 2 decluttering-card (the menu on the left is one, everything on the right is the other) using different variables (for entity, colour, visibility, etc etc - it’s a great way to create a consistent theme for your dashboard.
