(topic deleted by author)
Continuing the discussion from Accessing homeassistant from Node-RED when running on separate instance:
Why delete the post? Did you find a solution? Others with a similar issue may benefit from what you found.
The home assistant nodes allow server configuration and, within that configuration UI, there is an Enable global context store checkbox. This adds a homeassistant object to the global context.
