Toronto Hydro and Ontario Energy Board (Toronto Ontario, Canada)
I recently got a Shelly EM and I’ve been working on setting up the Energy Dashboard.
I’m really happy with the Shelly EM, so far (5 days) it is reading only 0.57% high compared to the Toronto Hydro Power Lens tool. Given more data, I may attempt to adjust it.
First question, Ontario Energy Board (OEB) rates are Time-of-Use on weekdays, AND Off-peak rates on weekends or holidays. I have worked out how to do this with a sensor:
    tou_label:
      friendly_name: 'TOU Label'
      value_template: >
        {% set is_holiday = states('calendar.oeb_tou_holidays') == 0 %}
        {% set is_weekend = now().strftime("%w") == 0 or now().strftime("%w") == 6 %}
        {% set is_summer = now().month >= 5 and now().month < 11 %}
        {% if is_holiday or is_weekend %}
          {{ "Off-peak" }}
        {% elif is_weekend %}
          {{ "Off-peak" }}
        {% elif is_summer %}
          {% if now().hour >= 7 and now().hour <= 10 %}
          {{ "Mid-peak" }}
          {% elif now().hour >= 11 and now().hour <= 16 %}
          {{ "On-peak" }}
          {% elif now().hour >= 17 and now().hour <= 18 %}
          {{ "Mid-peak" }}
          {% elif now().hour >= 19 or now().hour <= 6 %}
          {{ "Off-peak" }}
          {% endif %}
        {% else %}
          {{ "On-peak" }}
          {{ "Mid-peak" }}
          {{ "On-peak" }}
          {{ "Off-peak" }}
          {% endif %}
        {% endif %}
The Utility Meter Helper works with an automation:
automation:
    - platform: time
      at: "09:00:00"
      variables:
        tariff: "peak"
    - platform: time
      at: "21:00:00"
      variables:
        tariff: "offpeak"
    - service: select.select_option
        entity_id: select.daily_energy
        option: "{{ tariff }}"
        entity_id: select.monthly_energy
Has anyone figured out how to set the tariff with a sensor instead of an automation? I’d like to use my existing solution.
Finally, I found current rate info in XML form here:
https://www.oeb.ca/_html/calculator/data/BillData.xml
Can anyone point me towards how I would scrape my rate from this category?
<BillDataRow>
<Dist>Toronto Hydro-Electric System Limited</Dist>
<Class>RESIDENTIAL</Class>
For example, I would want to pull the data from:
<RPPOffP>0.082</RPPOffP>
<RPPMidP>0.113</RPPMidP>
<RPPOnP>0.17</RPPOnP>
This would automate updating the costs when the rates change.
If anyone is interested, I’ve also figured out the billing formula for Toronto Hydro from these rates.
I found this HACS integration, which pulls On/Mid/Off-peak from this very XML data, and it’s excellent.
I wish we could pull the rest of the rates from the XML data.
If it helps anyone, I’ve replicated the Toronto Hydro billing formula exactly:
