Hi all,
after update my Home Assistant via Portainer Stack, the integration with Toshiba AC is stop to work.
Here the message that I see into the log:
Logger: homeassistant.util.package
Source: util/package.py:159
First occurred: 14:44:36 (3 occurrences)
Last logged: 14:44:40
Unable to install package toshiba-ac==0.3.10: × No solution found when resolving dependencies: ╰─▶ Because azure-iot-device>=2.9.0,<=2.10.0 depends on paho-mqtt>=1.4.0,<2.0.0 and paho-mqtt==2.1.0, we can conclude that azure-iot-device>=2.9.0,<=2.10.0 cannot be used. And because only the following versions of azure-iot-device are available: azure-iot-device<=2.9.0 azure-iot-device==2.10.0 azure-iot-device==2.11.0 azure-iot-device==2.12.0 azure-iot-device==2.13.0 azure-iot-device==2.13.1 azure-iot-device==2.14.0 we can conclude that azure-iot-device>=2.9.0,<2.11.0 cannot be used. (1) Because azure-iot-device==2.11.0 depends on paho-mqtt>=1.4.0,<2.0.0 and paho-mqtt==2.1.0, we can conclude that azure-iot-device==2.11.0 cannot be used. And because we know from (1) that azure-iot-device>=2.9.0,<2.11.0 cannot be used, we can conclude that azure-iot-device>=2.9.0,<2.12.0 cannot be used. (2) Because azure-iot-device>=2.12.0 depends on paho-mqtt>=1.6.1,<2.0.0 and paho-mqtt==2.1.0, we can conclude that azure-iot-device>=2.12.0 cannot be used. And because we know from (2) that azure-iot-device>=2.9.0,<2.12.0 cannot be used, we can conclude that azure-iot-device>=2.9.0 cannot be used. And because toshiba-ac==0.3.10 depends on azure-iot-device>=2.9.0 and you require toshiba-ac==0.3.10, we can conclude that your requirements are unsatisfiable. hint: Pre-releases are available for `azure-iot-device` in the requested range (e.g., 3.0.0b2), but pre-releases weren't enabled (try: `--prerelease=allow`)
Is something that you have experimented?
The version of plug-in si 2024.12.0 (GitHub - h4de5/home-assistant-toshiba_ac: Toshiba AC integration into home-assistant.io) and the version of home assistant is 2025.3.1 ( Frontend 20250306.0)
Thank you all so much in advance
