Got it. Thanks for the pointer. Are you interested in extending to NA? I could probably do a capture at some point, but I can’t commit too much time to this unfortunately. Can you tell from the endpoint in my previous post if that’s the issue or not?
Hi all,
I was looking for help about issues i get with my toshiba Wi-Fi adapters (typeA).
I’m using Toshiba home AC official app. All was OK until i changed internet provider/router.
I tried to reset adapters, create another Toshiba account but i cannot pair adapters anymore. I get an error message at 79% during setup process.
I’m using V3.4 app and i wonder if an older release could work better? I read there was a FW update for adapters. How to check my current release? How to update?
Any help would be appreciate.
Thank you
I’m using the 2022.7.1 version of the Toshiba AC integration into home-assistant.io.
I’m trying to create an automation to adjust the temperature of the AC unit but I can’t find that action anywhere… there’s only possibilities to change the mode or turn the unit off.
I can adjust the temperature from the thermostat card in the HA.
I have the same issue, in addition I’d like to turn up the fan while heating when motion sensor hasn’t detected movement in the room for a short while. Did you find any answer to your problem?
