Total Average Daily Power Consumption
Im looking to see if its possible to create a sensor that gives me the average daily power consumption but updates when a new day starts… i hope i have explained this??
So for example if I manually calculate my average daily Power consumption its 14.83, but lets say I use more today, i would then expect that number to slightly increase.
Do you have a sensor that records your daily energy consumption measured in kWh or Wh?
The average for yesterday is easy enough:
template:
  - trigger:
      - platform: time
        at: "23:59:58" # misses 2 seconds of consumption in 24 hours (which is insignificant), but ensures the calculation is done before the daily sensor is reset.
      name: Average Daily Consumption Yesterday
      unit_of_measurement: "kW" # or W depending on your daily energy sensor
      device_class: power
      state_class: measurement
      state: "{{ (states('sensor.daily_energy_consumption')|float(0) / 24 )|round(2) }}"
      availability: "{{ states('sensor.daily_energy_consumption')|is_number }}"
If you want one for the current day that is a bit trickier, as you have to work out how many hours have been in the day so far, including fractions of hours.
template:
  - sensor:
      name: Average Daily Consumption Today
      device_class: power
      state: >
        {% set hrs = [ now().hour + now().minute/60, 0.01]|max %} {# this template only updates every minute so we don't have to worry about seconds, we do have to worry about it being zero though #}
        {{ (states('sensor.daily_energy_consumption')|float(0) / hrs )|round(2) }}
      availability: "{{ states('sensor.daily_energy_consumption')|is_number and (now().hour + now().minute/60) > 0 }}"
Hey Tom
Thanks for this. Im not sure this is what im after, but i could be wrong.
I did a quick simple math
I have used 1943kwh over 133 days since i started recording. This = 14.60kwh daily average.
Lets say i use 50kwh today which brings my total to 1993kwh
My daily average just went up = 14.87
Thats what im trying to achieve?
kw is not a measure of energy. Did you mean KWh?
Dividing KWh by h gives you kW (the h’s cancel)
So what you actually have is 1943kWh / (133*24h) = 0.608 kW average power draw.
Yes i meant Kwh sorry
Why would I convert it like that??
All I want is the average daily Kwh consumed
Regardless of what’s on the end. if I calculate my average daily power consumption based on what my energy dashboard shows me I have consumed in total so far it’s 14.60 as the average…
How do I get that but so it updates and takes into account the day just gone by?
Use a utility meter with a daily cycle.
That just gives me daily not the average of the total.
I’ll keep searching
What is the average of the total for a day?
You need to be much clearer about what you want.
I’m pretty sure I was
I tried to explain 2 different ways…
Hey there @cloudbr34k, did you ever figure out how to get this daily mean average of usage? I’m seeking this myself and have some thoughts, though not a full plan yet.
I have the start of an idea. I already used a built-in “Helper” (Energy Meter) to show today’s usage, and it keeps track of history. So it’s just a matter of extracting those days and doing the math. The Statistics - Home Assistant integration has some average functions that would work easily enough—it’s just a matter of fetching the daily values to feed in. I have no clue on that front, so far! I’m sure I’ll get there, but if you have had luck in the past 7 months, it’d save me a lot of time!
PS: I found your request pretty easy to understand. It was described okay initially, but became very easy to understand after you provided more detail. Maybe the moderator just has a slight language barrier? Though, you also provided math, so IDK! Anyway, just wanted to give you credit there.)
Thanks!
Did you solve it? I’m looking for the same thing right now.
So here are my sensor templates
# Template sensor to calculate the date of inverter installation
  sensors:
    fronius_installation_date:
      friendly_name: "fronius installation date"
      value_template: "{{ (as_timestamp(now()) - as_timestamp('2020-08-15')) / 86400 | int }}"
# Template sensor to calculate the date of smart meter installation
  sensors:
    fronius_smart_meter_installation_date:
      friendly_name: "fronius smart meter installation date"
      value_template: "{{ (as_timestamp(now()) - as_timestamp('2022-03-22')) / 86400 | int }}"
# Template sensor to calculate the ongoing daily average solar produced
  sensors:
    fronius_ongoing_daily_average_solar_produced:
      friendly_name: "Fronius Ongoing Average Daily Solar Produced"
      unit_of_measurement: "kWh"
      value_template: >
        {% if states('sensor.fronius_installation_date') | int > 0 %}
          {{ (states('sensor.symo_10_0_3_m_1_energy_total') | float / states('sensor.fronius_installation_date') | int) | round(0) }}
        {% else %}
          0
        {% endif %}
# Template sensor to calculate the ongoing daily average energy consumed
  sensors:
    fronius_ongoing_daily_average_energy_consumed:
      friendly_name: "Fronius Ongoing Average Daily Energy Consumed"
      value_template: >
        {% if states('sensor.fronius_smart_meter_installation_date') | int > 0 %}
          {{ (states('sensor.smart_meter_energy_real_consumed') | float / states('sensor.fronius_smart_meter_installation_date') | int) | round(0) }}
        {% else %}
          0
        {% endif %}
# Template sensor to calculate the ongoing daily average energy produced
  sensors:
    fronius_ongoing_daily_average_energy_produced:
      friendly_name: "Fronius Ongoing Average Daily Energy Produced"
      value_template: >
          {{ (states('sensor.smart_meter_energy_real_produced') | float / states('sensor.fronius_smart_meter_installation_date') | int) | round(0) }}
        {% else %}
          0
        {% endif %}
Here’s how I calculate the amount of energy used to heat water over a rolling window of 15 days:
  - platform: statistics
    unique_id: hot_water_energy_total_over_15d
    entity_id: sensor.hot_water_energy_meter # <- value only ever increases (e.g. utility meter with no cycle)
    name: "Hot water energy over the last 15 days"
    state_characteristic: change
    max_age:
      days: 15
The same approach applies to a rainfall sensor, for example. The important thing is that the state of the source sensor (entity_id) is monotonically increasing.
To get the average only requires one more sensor to divide by the size of the rolling window, 15 days in my example.
template:
  - sensor:
      - unique_id: hot_water_energy_average_over_15d
        device_class: energy
        unit_of_measurement: 'kWh'
        state: |
          {% set total_kwh = states('sensor.hot_water_energy_total_over_15d') | float %}
          {% set days = 15 * max(state_attr('sensor.hot_water_energy_total_over_15d', 'age_coverage_ratio'), 0.0001) %}
          {{ (total_kwh / days) | round(2) }}
