Hi All - new HA user here, so please excuse if I’m in the wrong spot!
I recently had a honeywell security system installed and connected through Total Connect 2.0. The panel showed up in my HA instance (raspberry pi) and I was able to sign in with a new user I created just for HA - so far so good. The technician came back yesterday to finish adding some motion detectors, and I noticed that the new sensors weren’t showing up in HA. I also noticed that even older sensors didn’t seem to be relaying information, so I thought something had gotten out of sync. I decided to try deleting the integration and adding it back, but after entering my User/Pass, HA gives an ‘unknown error’ message. My logs show some errors, but I’m not sure what to make of them - see the screenshot and text below. Thanks in advance for the help!
Here’s the text of the last error if it helps (the first 3 don’t contain anything beyond what shows in the screenshot).
Logger: aiohttp.server
Source: util/async_.py:140
First occurred: 6:04:59 AM (4 occurrences)
Last logged: 7:00:09 AM
Error handling request
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
resp = await self._request_handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_app.py", line 499, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 98, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 24, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 78, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 138, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 135, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 157, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 62, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 110, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 246, in async_configure
result = await self._async_handle_step(flow, cur_step["step_id"], user_input)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 320, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/totalconnect/config_flow.py", line 48, in async_step_user
return await self.async_step_locations()
File "/usr/src/homeassistant/homeassistant/components/totalconnect/config_flow.py", line 91, in async_step_locations
for location_id in self.client.locations:
File "/usr/local/lib/python3.9/site-packages/total_connect_client/client.py", line 97, in locations
location.get_partition_details()
File "/usr/local/lib/python3.9/site-packages/total_connect_client/location.py", line 202, in get_partition_details
result = self.parent.request(
File "/usr/local/lib/python3.9/site-packages/total_connect_client/client.py", line 190, in request
r = eval("self.soap_client.service." + request)
File "<string>", line 1, in <module>
File "/usr/local/lib/python3.9/site-packages/zeep/proxy.py", line 46, in __call__
return self._proxy._binding.send(
File "/usr/local/lib/python3.9/site-packages/zeep/wsdl/bindings/soap.py", line 127, in send
response = client.transport.post_xml(options["address"], envelope, http_headers)
File "/usr/local/lib/python3.9/site-packages/zeep/transports.py", line 107, in post_xml
return self.post(address, message, headers)
File "/usr/local/lib/python3.9/site-packages/zeep/transports.py", line 73, in post
response = self.session.post(
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 590, in post
return self.request('POST', url, data=data, json=json, **kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 542, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 699, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 394, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 239, in request
super(HTTPConnection, self).request(method, url, body=body, headers=headers)
File "/usr/local/lib/python3.9/http/client.py", line 1279, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/local/lib/python3.9/http/client.py", line 1290, in _send_request
self.putrequest(method, url, **skips)
File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 219, in putrequest
return _HTTPConnection.putrequest(self, method, url, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/util/async_.py", line 151, in protected_loop_func
check_loop()
File "/usr/src/homeassistant/homeassistant/util/async_.py", line 140, in check_loop
raise RuntimeError(
RuntimeError: I/O must be done in the executor; Use `await hass.async_add_executor_job()` at homeassistant/components/totalconnect/config_flow.py, line 91: for location_id in self.client.locations:
