Meanwhile the update from version 0.85 to 0.86.2 drives me crazy (hass.io on Raspberry Pi 3). First the problems with double underscores, then the story with the “time trigger”. At first, hass.io even didn’t want to start any more, but after I solved all problems (thanks to my SD-Card Image-Backup) mentioned above, hass.io now runs on version 0.86.2.
But the story is not over yet… When I click “Try out the new Lovelace UI”, there is only an error “Error while loading this panel”… No more information, no log entries, nothing…
I did try Lovelace UI before under versin 0.85.2, but I don’t have switched the default UI to Lovelace UI, now with 0.86.2 Lovelace UI does not run at al…
BTW, I don’t have a “ui-lovelace.yaml” so far.
Uhh, Browser cache clearing and browser restart did it! Lovelace UI loaded!
OK, next step is configuring… will take some time and will bring some other problems, I’m pretty sure!
Anyway, Lovelance UI is up and running! Thanks for your help!
