EDIT: A fix is in for 2022.5.3 - hopefully when that comes out this will be resolved!
After installing HA Core version 2022.5.1, the TotalConnect integration no longer stays logged in after about 6 hours.
It will re-attempt logging in about 3 times, failing each time, then it will ask that the integration get reconfigured where I can re-input the TotalConnect password. After that it will work again, but only for 6 hours or so.
Re-starting Home Assistant will also fix it, again, for just about 6 hours.
So after installing 2022.5.3, it appears that the Total Connect servers are logging us out every 5 hours. I have a notification setup on my Total Connect account to let me know whenever there is a new login via the app or website, and I can see it login 4 times every 5 hours all night long!
The good news is that it appears that Home Assistant is able to keep connected this way, but now I have all these annoying alerts that I can either choose to turn off on the Total Connect side, or filter out my email client side.
I do wonder if this is going to cause any issues going forward; it appears that Total Connect has decided to “expire” long logins for some reason now and I hope this new behavior won’t trigger some kind of lockout.
