Touch E3 / CleverTouch radiators (Purmo, LVI, Radson): local 868 MHz control with ESPHome + CC1101, no cloud
Hi all,
I have a house full of Purmo Yali Digital radiators that I have been able to control with a Touch E3, which has a cloud integration so you can control the radiators with e.g. your phone.
I’ve been using the CleverTouch integration to get them into Home Assistant. There’s nothing wrong with the integration itself, but everything goes through the cloud, which is slow to update and every now and then just doesn’t answer. So I started wondering: the E3 talks to the radiators over 868 MHz, so could an ESP32 with a cheap radio module do the same, with a bit of help from AI?
(Small heads-up here: this has been co-written with Claude, both the code and the docs. If that’s not your thing, no hard feelings, you can stop reading here.)
Well, it turns out it could, and it has been working really well! The radio protocol isn’t encrypted, and after a good amount of logic analyser captures, logs and pressing radiator buttons, my seven radiators now run on an ESP32 and a CC1101 with ESPHome. The E3 has been unplugged since early November, apart from some testing.
GitHub - jbacklun/esphome-clevertouch-radio: ESPHome component to control CleverTouch (Touch E3) electric radiators over 868 MHz with an ESP32 and CC1101 · GitHub
This is what my “controller” looks like:
The CC1101’s own spring antenna did pretty badly once everything was inside the case, so I tried a simple wire dipole instead (two 82 mm wires, one up from ANT, one down from GND). That worked a lot better.
What you get
  • A climate entity per radiator: off / heat / auto, with comfort, eco and away presets
  • Room temperature, heating power and energy for each radiator
  • A week schedule that runs on the ESP itself, so it keeps going when Home Assistant or Wi-Fi is down (the ESP just needs to have got the time first). You can edit it as text or with a Schedule helper (blueprint included)
  • The radiator’s own buttons and timer still work, and what you do there shows up in Home Assistant
  • Changes usually reach the radiator within a second or two, instead of waiting for the cloud
Want to try it?
If you have an E3, you don’t need to re-pair anything. The ESP only listens while the E3 is running. Unplug the E3 and the ESP takes over after 5 minutes. Plug it back in, and the ESP steps back. So it’s pretty safe to play with.
If you don’t have an E3 (or it’s broken), you can pair the radiators directly to the ESP.
The component’s part of the YAML is short:
external_components:
  - source: github://jbacklun/[email protected]
    components: [clevertouch_radio]
clevertouch_radio:
  control_radiators: DEFAULT_ON
  radiators:
    - name: Bedroom
      radio_id: F1234567   # the Device ID your E3 shows
      watts: 750
Don’t know the ID? Leave radio_id out. Radiators the ESP hears show up in Home Assistant with their IDs, and a radiator you pair from the ESP shows its ID too.
You also need the radio settings and a few other bits. There’s a complete example with wiring in the repo.
What I haven’t been able to test
  • Other models and brands. I only have Yali Digital. The E3 is also sold as LVI and Radson, among others, and those should work the same way, but I can’t promise anything.
  • Double-panel radiators. Controlling them should be no different, but the energy figure is an estimate if you use the front panel limit.
  • A completely fresh install without any E3 history. Pairing itself works (I’ve paired two new radiators from the ESP), so this should work too. I just haven’t had a chance to try it with a controller that has never seen an E3.
  • Several ESPs in a big house, each with its own radiators. Should also work, but not tested.
If you try any of these, I’d love to hear how it went!
Got Watts Vision, or other things paired to your E3?
Thermostats, receivers and so on don’t work yet. But I found some published frames from Watts Vision thermostats, and they have the same layout as the ones my radiators send, so support may well be possible. I just don’t have the hardware.
If you do, a log would be a great help. With “Control radiators” switched off (control_radiators: DEFAULT_OFF), the ESP only listens and never transmits, so you can’t break anything. The README explains how (“Other devices: how to help”), and the protocol is written down in docs/PROTOCOL.md for anyone curious.
Questions and feedback are very welcome!
(Not affiliated with Purmo, CleverTouch or Watts.)
