Recently I had one of the TP-Link hs200 switches in my home disappear from HA.
I have about a dozen. All except one are fine.
Things I have tried.
- factory reset switch and re-add with app
- static assigned IP address
- remove all tp-link devices and restart HA. All but the one was auto discovered
- add the switch directly in configeration.yaml
- removed the switch from the app and re-add.
I would be inclined to suggest bad wifi signal maybe, but it is in a two gang box with another HS200 that is perfectly stable.
I am at a loss as to what has happened or how to get it back. Really a bit miffed since I would have to replace two switches to get this functionality back – I want them to look the same.
Any ideas what I could do next? Like is there some sort of malformed cached entry somewhere that I could clean out?
