Hi All-
I have some 3rd party switches that should show as TP Link 105s (Voion). When I add the TP Link component, I get the following error in my log.
2017-06-12 17:41:34 ERROR (MainThread) [homeassistant.components.switch] Error while setting up platform tplink
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py”, line 160, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
File “/usr/lib/python3.4/asyncio/tasks.py”, line 372, in wait_for
return fut.result()
File “/usr/lib/python3.4/asyncio/futures.py”, line 277, in result
raise self._exception
File “/usr/lib/python3.4/concurrent/futures/thread.py”, line 54, in run
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/switch/tplink.py”, line 36, in setup_platform
from pyHS100 import SmartPlug
File “/home/homeassistant/.homeassistant/deps/pyHS100/init.py”, line 4, in
from pyHS100.pyHS100 import SmartBulb, SmartPlug, TPLinkSmartHomeProtocol, SmartPlugException
File “/home/homeassistant/.homeassistant/deps/pyHS100/pyHS100/init.py”, line 4, in
ImportError: cannot import name ‘SmartBulb’
I am running Hassbian with version .46. I have seen the TP LInk posts in here and it looks like support had been added in version .43.
I have also updated the python component with:
sudo pip3 install pyHS100==0.2.4.2 --upgrade --target /home/homeassistant/.homeassistant/deps
Prior to this update, I had gotten a lot more error messages when including the component.
Switch configuration is just:
- platform: tplink
host: 192.168.1.31
Any ideas?
