TP-Link Device tracker still not working
TP-Link device tracker still is not working after upgrade to 0.52. It has been sice versio. 0.48 as I remember.
Any help?
Regards
I’m using it on 0.52 with a TP-Link Archer C5 and am not experiencing any problems, you might want to add more details.
Component is not loaded at all.
Log entry - I used from older version by now is the same.
017-08-01 19:24:06 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform tplink
File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/requests/packages/urllib3/response.py”, line 302, in _error_catcher
yield
File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/requests/packages/urllib3/response.py”, line 384, in read
data = self._fp.read(amt)
File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/http/client.py”, line 449, in read
n = self.readinto(b)
File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/http/client.py”, line 493, in readinto
n = self.fp.readinto(b)
File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/socket.py”, line 586, in readinto
return self._sock.recv_into(b)
ConnectionResetError: [Errno 54] Connection reset by peer
I already filed an issue here, just some days before you did:
https://github.com/home-assistant/home-assistant/issues/9120
Maybe you should link it to mine so there will only one thread about it.
Is the Device Tracker still broken? I cannot check anymore because I flashed my TP-Link router to OpenWRT. They are cleaning up the issue’s on Github and they asked wether it is working or not with the latest HA version.
Hello
TP-Link Archer C5 AC1200 V4 not working
