Something’s funky with my HS110 unit. It gets unavailable a lot happens more in specific periods of the day.
You can see from this image that the unit spent a lof of time in the Off state, from 12AM to 6PM. During the morning and most of the day we’re offline or working and the unit stays most of the time well connected. But after 6PM, we’re home, and the unit starts losing the connection very frequently, almost every 10-15 minutes.
It’s setup in a place where it gets from -70 to -80 RSSI.
What could be the issue? That unavailable pattern when we’re out it’s weird
I’d be guessing WiFi signal too. If you are getting -70 or -80 at the switch, imagine the signal level back to the access point considering how crappy the antennas would be inside these things.
I’ve got one attached to a dishwasher which is under a stainless steel bench, it gets 0-3 dropouts per hour. I’ve got another pair for a washer/dryer and they sit on top of the unit, with perfect clearance of any major obstacles, they are rock solid.
