Tp link HS110 energy values will not change
I can turn the plug on/off but the energy values will not change.
I upgraded from 0.114 to 0.116.2 but no change.
I used the GUI to integrate the plug and adapted the configuration file as follewed
and the result is:
and the values will not change.
In the TP link smart app it is changing.
I changed it to this and now is it working
    sensors:
      tp1_amps:
        friendly_name_template: "{{ states.switch.tp1.name}} Stroom"
        value_template: '{{ states.switch.tp1.attributes["current_a"] | replace(" A", "") | float }}'
        #value_template: '{{ states.switch.tp1.attributes["current_a"] | float }}'
        unit_of_measurement: 'A'
      tp1_watts:
        friendly_name_template: "{{ states.switch.tp1.name}} Moment_verbruik"
        value_template: '{{ states.switch.tp1.attributes["current_power_w"] | replace(" W", "") | float }}'
        unit_of_measurement: 'W'
      tp1_t_kwh:
        friendly_name_template: "{{ states.switch.tp1.name}} Tot_energie"
        value_template: '{{ states.switch.tp1.attributes["total_consumption"] | replace(" kWh", "") | float }}'
        #value_template: '{{ states.switch.tp1.attributes["total_consumption"] | float }}'
        unit_of_measurement: 'kWh'
      tp1_volts:
        friendly_name_template: "{{ states.switch.tp1.name}} Spanning"
        value_template: '{{ states.switch.tp1.attributes["voltage"] | replace(" V", "") | float }}'
        #value_template: '{{ states.switch.tp1.attributes["voltage"] | float }}'
        unit_of_measurement: 'V'
      tp1_d_kwh:
        friendly_name_template: "{{ states.switch.tp1.name}} Energie_vandaag"
        value_template: '{{ states.switch.tp1.attributes["today_energy_kwh"] | replace(" kWh", "") | float }}'
        #value_template: '{{ states.switch.tp1.attributes["today_energy_kwh"] | float }}'
