TP-Link HS210 3-Way Switch Wiring Issue
Hi All,
Recently got the HS210 and have success installing them around the house. I ran into one switch that’s giving me issues.
The switch is running this setup right:
I installed the switch is the behavior i’m observing:
  • Light ON --> smart switch got no power (but if i remove one of the traveller, i see switch power on)
    *I go turn off the LIGHT with switch that is NOT SMART. Smart switch blinks a few times, light turns on, smart swtich resets, light goes off, and process repeats.
No idea what could be the issue? Was wonderign if anyone knows and if i have provided enough information?
Bulb the fixture using is a Single GU24 23W 380mA
Similar to this guys issue:
https://forum.tp-link.com/showthread.php?105394-Having-issues-with-HS210-kit-installation
Thanks in advance,
Regards,
Kevin
My hallway has the same wiring and I’m having a similar issue. Any update?
you can use sonoff mini for this scenario, works great, 6$
