I’m encountering a strange issue trying to add some new Kasa / TP-Link HS200 switches to my Home Assistant configuration. I am no stranger to Kasa/TP-Link products have successfully integrated 40+ Kasa devices into HA.
Here are the details:
Currently running HA v2023.7.3 as a VM on Unraid (v6.12.3)
I added 3 new HS200-BL Kasa switches and connected them to my usual IoT VLAN’ed wireless network.
I have assigned static IPs (and also tried with dynamic IPs assigned by my Unifi router)
I have added the IP addresses into my config.yaml (same as I’ve done with the other 40+ Kasa devices)
I have restarted HA multiple times
I have restarted the entire network multiple times
I have restarted Unraid
I have power-cycled the switches
I can see and activate the switches directly within the Kasa / TP-Link app (as well as Smartthings - which I do NOT have integrated with HA)
When I try to auto-discover the new devices, they are not found. When I try to manually enter the IP address, they are still not found.
I don’t think that I’m doing anything differently than I had before with all of my other Kasa switches.
Any advice or troubleshooting that I should review?
Screenshot of how I’ve previously setup the “host” IPs within the config.yaml:
Update - I just tried adding a new HS200 (not the HS200-BL) and it added perfectly to my Home Assistant. Something is definitely different about the HS200-BL (the “-BL” is for the black switch).
Per the user manual, there is a different setup/initialization procedure for the HS200-BL which seems to connect to the switch via Bluetooth (?) first and then assigns the wifi credentials.
Still - my Unifi router sees the HS200-BL switch just like it does all of my other HS200 (non “-BL”) switches. It’s on a 2.4GHZ IOT network with a static IP.
