Could someone help me configure my TP-Link/Kasa integration?
I had it connected but found it wasn’t finding new devices. I removed the integration and on trying to reinstall it simply would not find the host when I leave it blank in the setup process.
When I try the integration again, it still has an error finding a host.
I’m not understanding what to do - is anyone able to assist, please?
Out of interest - the home assistant server is on the .86 subnet, while the devices are on the .10 subnet - however, I have not yet enabled ANY firewall restrictions between these subnets and other integrations find devices on that subnet without issue…
I’m assuming these are Smart Plugs? Have you checked the firmware isn’t the latest? The local API was removed/blocked and if the devices are up-to-date they will not work.
The beta firmware they were also offering is no longer available.
For me this was the reason to ditch the Kasa plugs and move to Shelly plugs. Those work locally and even the cloud functionality needs to be actively enabled! Well done, Shelly!
Check out the Shelly S Plug (compact, up to 2500W) or the bigger Shelly Plug (up to 3600W)
