Issue: Unable to see TP Link bulbs in Home Assistant & for the same reason harmony hub doesn’t see any Philips Hue light available to be added in activity.
I have Harmony hub running in my Living room which almost controls everything except TP Link bulbs, Sonoff smart switch and my smart motorized curtains.
I thought of using Home Assistant to control all these things with Harmony Hub remote.
My Configuration.yaml:
emulated_hue:
listen_port: 80
switch:
- platform: tplink
host: 192.168.70.131
Able to control these bulbs using pyhs100
Example:
(homeassistant) homeassistant@raspberrypi:/home/pi $ pyhs100 --ip 192.168.70.131 on
No --bulb nor --plug given, discovering…
Turning on…
and
No host name given, trying discovery…
Discovering devices for 3 seconds
== Shade Two - LB110(US) ==
OFF
Host/IP: 192.168.70.131
Brightness: 75
Is dimmable: True
== Generic information ==
Time: None
Hardware: 1.0
Software: 1.8.6 Build 180809 Rel.091659
MAC (rssi): 50C7BF3FBAC1 (-41)
WARNING:pyHS100.smartdevice:Unsupported device location.
== Emeter ==
Current state: {‘power_mw’: 0}
== Shade One - LB110(US) ==
Device state: ON
Host/IP: 192.168.70.138
Brightness: 75
Is dimmable: True
Time: None
Hardware: 1.0
MAC (rssi): 50C7BF2BCE40 (-51)
== Emeter ==
Current state: {‘power_mw’: 8300}
Details of platform running on Raspberry Pi3 B+:
Manually installed Home Assistant on Virtual Environment (https://www.home-assistant.io/docs/installation/raspberry-pi/)
Home Assistant: Home Assistant 0.85.1
Philips Hue successfully added after setting configuration.yaml and Harmony hub also able to add it as a device but Home Assistant only detecting my Samsung Smart TV and considering it as my light
TP Link: LB110
Hardware Version: 1.0
Firmware Version: 1.8.6
