Tp-Link router fails with DuckDNS.org
Hi guys,
After so much time spent to find a way to give access to my Home Assistant outside my private network, I finally find a way :v:
First of all, yes… I’ve read all the topics, watch all the videos… and nope… nothing works with the TP-Link router !
Yes, you have to do all the steps about DuckDNS with your home assistant (there is lots of topics about that, and Youtube videos).
After that, you have to go to your TP-Link configuration board, and reserve your HA IP address :
Go on Network -> DHCP -> Add (search your HA IP and MAC)
After that you have to be sure that IP address is open to the world :
NAT Server -> Virtual Server -> HTTP for the service, 8123 for the interne and externe port and TCP Protocol (if you are really struggle after all this post try to add too the 443 port (SSL access).
And now as all the topics on the web you should have access to your HA ???
NOPE…
You can spend hour and hour to try to reach your IP Address and the 8123 port… and nothing happen… so no DuckDNS access too.
Why ?
Because of your internet provider and his box of course :man_facepalming:
So… you have to go directly to your internet provider box settings :
  • As above for your router settings, in the NAT Server section add your router IP address (not your HA IP -> you can’t anyway, they are not on the same network)
  • Do not forget to add you HA port internal and external (8123)
Et voilà !
Now you can finish all the settings with DuckDNS, and control you HA anywhere in the world :wave:
HI There. I am using Archer MR600 (LTE router) and have the same problem with HA and DuckDNS. In my mcase MR600 is my internet Provider so no additional Provider box settings. Any idea?
I’ve changed of provider and they do not accept Nat Loop… impossible to find a way… so my only choice was to pass by Apple TV and Home Apple App.
I’m currently using a 4g router from TP link (TL-MR6400 specifically) and the only DDNS options available are their own, Dyndns and NO-IP. There’s no other box for me to configure. I currently use HA as a hub for Apple Home, so I’m not really sure if your solution would be possible for me, but would you mind elaborating anyway? I’m curious to know what other options are out there because I’m locked out of HA otherwise (unless I use a local url).
