TP Link Smart Plug HS110(UK) Platform Not Found
I am new to Hass.io and I am having trouble configuring my tp-link smart plugs HS110(UK).
I’ve added the following to the configuration file:
switch:
  • platform: tplink
    host:192.168.1.252
Configurator says its ok so I save, I then validate the configuration file but I get an error:
Configuration invalid
Platform not found: switch.tplink name:“Lamp1” host:192.168.1.252
in the logs its says:
Unable to find component switch.tplink name:"Lamp1" host:192.168.1.252
Any ideas?
Cheers
Darren
Mine is formatted as follows and works fine for me. I don’t have quotes around the name if that makes a difference.
switch:
  - platform: tplink
    host: 192.168.0.12
Hope that works for you.
Check your spacing before the IP address and the name.
Thanks for the tips. I think the issue was Configurator and the formatting at was using.
I made the changes in Notepad++ and everything then worked.
I’ve now setup my switches to turn on at sunset and it’s working fine.
Cheers
Darren
