I’ve been using my TP-Link HS-110 switches for a while in HA. However since the update to 0.33.1 (did not happen in 0.33 base) they no longer load. Nothing in my config has changed and the error in the logs is as follows:
16-11-21 17:09:01 homeassistant.components.switch: Error while setting up platform tplink
File "/usr/local/lib/python3.5/dist-packages/homeassistant/helpers/entity_component.py", line 150, in _async_setup_platform
entity_platform.add_entities, discovery_info
File "/usr/lib/python3.5/asyncio/futures.py", line 361, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 296, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 274, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/switch/tplink.py", line 43, in setup_platform
add_devices([SmartPlugSwitch(SmartPlug(host), name)], True)
File "/home/tino/.homeassistant/deps/pyHS100/pyHS100.py", line 35, in __init__
self.model = self._identify_model()
File "/home/tino/.homeassistant/deps/pyHS100/pyHS100.py", line 254, in _identify_model
sys_info = self.get_info()
File "/home/tino/.homeassistant/deps/pyHS100/pyHS100.py", line 70, in get_info
return self._send_command('{"system":{"get_sysinfo":{}}}')
File "/home/tino/.homeassistant/deps/pyHS100/pyHS100.py", line 244, in _send_command
s.connect((self.ip, self.port))
socket.gaierror: [Errno -3] Temporary failure in name resolution
I find the error odd since it is added by IP address and no resolution is needed. Both IPs can be reached from the server too.
Yeah, the HS-110, in addition to wifi on/off control, reports the following things:
Current Consumption in W (at that moment)
Current in A (at that moment)
Daily Consumption in kW
Voltage
Total consumption (I assume since the start of using it) in kW
While I would prefer actual in-wall z-wave controlled outlets, I really am fairly satisfied with the TP-Link ones and would probably pick up a few more if the price was right.
