I’m new to Home Assistant, and would like to integrate my 3 TP-Link Tapo C310 cameras. When I add the integration it fails to discover any cameras on my local network. When I manually specify a camera’s IP Address, I get an error that it cannot connect to port 9999.
The camera in question is running firmware version 1.3.9.
I’ve performed a port scan and the camera has the following ports open:
443 TCP
554 TCP
8443 TCP
2020 TCP
8080 TCP
1030 UDP
3702 UDP
16896 UDP
19161 UDP
19682 UDP
32775 UDP
33744 UDP
35794 UDP
42056 UDP
42434 UDP
47808 UDP
49179 UDP
49188 UDP
The camera was enabled for uPNP so not sure if most of the UDP ports were auto created and will disappear or change after a router reset.
Has anyone had any success in setting up a TP-Link Tapo C310 device on Home Assistant recently?
