Tp-link tapo camera error
I bought the Tapo C200 camera, I installed the integration, it detects it perfectly but when it comes time to see it, it appears unavailable (or inactive). I leave you an image! thanks in advance
log:
Registrador: homeassistant.components.stream.stream.camera.camara_cocina_hd_stream
Fuente: components/stream/init.py:448
integración: Stream (documentación, problemas)
Ocurrió por primera vez: 18:53:01 (16 ocurrencias)
Último inicio de sesión: 19:13:11
Error from stream worker: Error opening stream (INVALIDDATA, Invalid data found when processing input) rtsp://:@192.168.0.90:554/stream1
Which Integration ? ,
if it’s Tapo-Camera-Control, you should not provide an RTSP: Address
Maybe you want to try with the “Generic Camera” integration
yes tapo control
And which Card are you using ?
If you look at below “Sensores” where HD/SD streams are, it says No Disponible
Maybe you didn’t follow the Installation, steps from the Integrations Documentation correct
PS: If it doesn’t work with above settings, and in i.e. “picture-entity-card”
show_state: false
show_name: false
camera_view: live
type: picture-entity
entity: camera.your-cam/entity-name_stream
BTW. This is the official Project Page, for Tapo-Camera-Control Integration
Above is incorrect.
If your RTSP stream does not work but the control does, check faq you have too many connections going out to rtsp of camera.
