I had a simple one (only letters) and when i ask to change it TAPO app ask for a new one with letters, capital letters, number and special formats,
It works with me
I’ve got my P100 up and running with the Tapo app, and verified its IP address. I’ve copied the tapo_p100_control folder to my custom_components folder, and added this to my configuration.yaml:
Hello, @fishbigger I wanted to install the PyP100 library which was placed on github but entering the command gave me an error which I couldn’t fix, could you help me please
This is an interesting problem…I released a new version of this integration. I think there are many improvements from the old one. “Invalid credential” was resolved by a pull request to my plugp100 library, but regards the light bulb, try if with this new version it works.
Just want to drop a note here to thank you for the great work. I’m brand new to HA and bought a P100 because it was cheap, but before I checked compatibility. Was about to return it when I found this thread and got it up and running! Thanks very much!
Had to create an account to say a big thanks to the authors of that python script. As of 15th August '21, you can still use the Tapo app, update their firmware (1.3.0 Build 20210310 Rel 63416) to the latest, and they show up just fine.
My first “gotcha” was after I did git clone, it put the .py files in a subdirectory:
My second “gotcha” was not giving them a custom name in the Tapo app.
My third “gotcha” was not knowing they would show up as an Entity, not a Device
My final “gotcha” was setting my configuration.yaml incorrectly when doing multiples, they must have the “-” before each platform entry when you have multiples:
I have two plugs, one is solely used to detect if power is being drawn by my PC monitor (isn’t used to turn anything on or off). I have another Tapo plug that is controlled by an automation that detects when my monitor turns on/off and turns on/off some speakers (so basically the speakers come on and off in sync with the PC monitor)
The automation detects when power is being drawn or not and runs ok, turning on and off the second Tapo plug. But the first plug (that is doing the monitoring) seems to be pulsed off and on for a second or two when the speakers turn on. HA isn’t showing the monitor plug going off, it’s state is constantly on.
I’m trying to add a 2nd P100 to my setup, but for some reason it isn’t showing up on my HA developer console. The first switch is listed OK, but not the 2nd.
Both are visible in the Tapo app, and I’ve verified that the IP address is correct. I also restarted HA after plugging in the 2nd P100.
Here’s my config:
The entity has attributes. With the supplied custom python script it only offers KWh as an attribute. I’ve modified it to show Wattage (in “real-time”)
