Thanks for this guy’s. Now I can buy more tapo plugs. Works nicely.
Logger: homeassistant.helpers.entity
Source: helpers/entity.py:477
First occurred: 3:18:41 (1 occurrences)
Last logged: 3:18:41
Update of switch.kerstboom is taking over 10 seconds
I’ve recently bought a box of four Tapo P100 sockets and they’re great but as we already know, they can only be controlled in the tapo app. Well, until I found this. I’m very interested in installing this in my raspbery pi as soon as I get home in the next weeks.
Anyway, about this topic, I was trying the python code and I get the following error:
I am trying to set up two plug, this is in my config file, but i cant find the plugs in the entity section.
Apologies if the terminology isn’t correct i am a complete noob to HA.
Platform does have the dash before, i think this formats differently.
I had the error others mentioned until I change the password to 8 chars 1 number and 1 upper
The formatting below works for more than 1 plug
Restarting the Supervisor|System|Core|Restart Core several times somehow fixes things. Give it a few minutes after a restart to register everything.
I think it important to know what “working” means. Once working your new device will appear in the Configuration|Entities list. It will no appear in the Integration or Devices tab.
Thanks VM for those that helped me get this working.
I just remove customs_components folder and configuration.yaml entries and made all again step by step with in between reboots.
Error disappear but I’n not seeing any new device or entities.
What’s your recommendation?
Congrats!
I’m on the same position… not working
I just uninstall everything and do it again… but it stills doesn’t working and doesn’t showing any device.
Hi Guys,
also having some issues getting things to work.
I am now passed the "no module named ‘PyP100’ error by adding the folder and then restart before adding the config entry, and then restart once more. So far so good.
Now I am having the authentication issue: Exception: Error Code: -1501, Invalid Request or Credentials
I have tried to change my password to something not so cryptic, only having one capital letter and numbers, no special characters. It’s 9 characters in length is that an issue. ?(shouldn’t be I guess as the installation example on Github shows 11)
I am able to login using the Tapo app and confirm the account still works wit the new password and email, but so far in HA no luck!
Was there also something about you couldn’t use the primary tp-link account to connect to the switch, or it doesn’t matter which user you use?
I also tried adding the credientials directly instead of secrets file.
I am using latest version on my pi3b
Version 2021.1.5 Home Assistant OS
Home Assistant OS 5.10
Sorry for the error the installation on github is just showing where to put your password. On some occasions changing to a 8 letter password worked and other people have tried forgetting all the devices and readding them. For some reason tapo don’t like the encryption on some types of passwords.
I will try to change it to 8 letter instead and also afterwards the remove / re-adding part.
Thx.
EDIT: So I tried to remove the switch from Tapo and add it again. Perhaps this is an issue when you have to change user password to something else and the entries has to be “re-authenticated” back in! don’t know. I did stay on the password with 9 letters, but now I am actually thinking about trying to go back to the old password more complicated and with special characters to see if it works. Or is it confirmed that special characters is a NO GO. Otherwise no need for me to try. also entity came in as the real name, and I didn’t have to do anything it just works, and fast. Spend a long time with this and Finally this plug is in HA.
Thanks for suggesting to remove the device it self.
