TP-Link Tapo P100
Nice research again @GSzabados!
Unfortunately I do not own tapo plugs, so I am not able to work on this. I stick with the well supported tplink hs110 with api available.
Getting API reverse engineered is the best option but Iā€™m using the following combination:
Pair Tapo with Google Assistant, Install assistant-relay (execute google home commands via api), hass.io making requests to assistant-relay.
Iā€™ve watched what tapo app is sending and after a while Iā€™m able to generate valid TPIoTRequest which are sent to the p100. (p100 answers with error_code:0 so itā€™s valid)
Now I will try to decrypt the answer from the p100.
edit:
Iā€™m able to decrypt answer from the p100! So when sending login_device request, p100 sends {"error_code":-1501} backā€¦ I can communicate with p100 but my username and password are not correct.
Bingo! Username & Password needed to be base64 encoded + username needs to be a SHA-digest.
P100 answers: {"error_code":0,"result":{"token":"887E98FF98EB90AB1......9D0881A98"}}
Sounds very promising! Great work. :ok_hand:
Do you think this opens the door for a functional integration?
I think I should be able to send on/off requests
After that point the P100 communicates by using the token the way how it is in this post:
Thanks for picking up this work and carrying further!
More progress!, Iā€™ve patched the android app with my pre-made key pair, so I can decrypt all information the app is sending/receiving to/from p100. (Itā€™s easier to reproduce pure HTTP requests than searching through decompiled code for requests)
App sends this request to change the state of the plug:
{"method":"set_device_info","params":{"device_on":false},"requestTimeMils":1602840338865,"terminalUUID":"88-54-DE-AD-52-E1"}
I can now craft it dynamically, so I can change the plug state (turn on/off) with my own code!
Edit: Now, itā€™s time to document it and create repository with an PoC.
Great work to all of you guys!
Really incredible what you achieved so far!
Definitely easier, great work!
Ah, nice technique.
So the plug uses the key pair from the app? Interesting!
Iā€™ll take a look at the Bluetooth packets tomorrow :+1:
Yup, Iā€™ve written a post about the connection here: https://k4czp3r.xyz/posts/reverse-engineering-tp-link-tapo/
Great write up!
So, last night i paired a new p100 and i had packet capture enabled, but it failed to capture any packets.
However, while i was looking for the cached firmware, i found what looks like the AES key.
/mnt/sdcard/Android/data/com.tplink.iot/files/model_cache/deco_model/deco_model
its a txt file with two key:value pairs.
"DECO_TPSERIALIZEUTILS_AES_KEY":"skf6gYCmI25E1mcE9WvDWG5wxdExTTAtOeNrFN5aui1SMEHK6Udx9XEgsaDL1ifJEPcDce9gHbSB\nnqfAeSdcTvt+JNP7KBxTdGgU64irT2i8pt+uBxhODNmN\/PX5g2PorsnjsUs6op8us8v4xFxWsSp2\ng4jQLdEgbEkluTz8\/I+htZrgUvaV8EUWVy6oz0nSdkG5b8DJutna\/iqJOO75P2AaqSCf8fnLZet6\ntK1zrSa3+GBifnK+J98gjXn6I6kxkPPUWbRA0JTZhLS+JvLEAa4W34+ZggdFo6soeK7Ga\/gGUy1M\nls2xMSihnt9UR7MO6+P3cLKxu6COZzLbO7bPVQ==\n",
"DECO_TPSERIALIZEUTILS_AES_VECTOR":"IDoSrxMmme+YrIwVJ0tv2tI+ZcCYOPMgprpqwPdgsCu\/ncM4WY6BXNN272KaAHkrAlu+nbNHqa51\nxufCO2DsJz6eQjkuq9IUYw9mzeHsgU4\/lsHJmFd2thfdppaHyIGrFlYA5O\/mfC2gMBMSpXKxXq4G\nyhaxKHN7jynghLrHO6i9d3TvoFXPNbHc0+Koo7COIBMHNn6EbNMSlzrSWi7TEoX7NBwPf\/5FZcnL\ntV+d1IrShHeACrmF2D6ufJkXvaPuA3SIZ7lecdzlTn9ixrBWbJ4cZY3V\/2f7d2vTfm9QxDxkorbQ\n0h8DQtQ\/ub59rdcvjEmRfE9tHZwpLUNHmYOBgQ==\n"
@K4CZP3R, will you make a custom integration?
I should be able to make a pip package and a custom integration next week. Assuming nobody else wants too before then :slight_smile:
Sounds like @fishbigger will make one :wink:
Hey,
Iā€™m currently working on a pip package for the plug but Iā€™ve hit a problem. I am sending the turn off code to the plug using requests.post
def turnOn(cookie):
	URL = "http://192.168.0.157/app"
	Payload = {
		"method": "set_device_info",
		"params":{
			"device_on": "false"
		"requestTimeMils":1603557345731,
		# "terminalUUID": "1c:3b:f3:a5:71:e5"
	headers = {
		"Cookie": cookie
	r = requests.post(URL, json=Payload, headers=headers)
The request is coming back with
{"error_code":0,"result":{"response":"SCJqlRa0KLL06A3YSoTiqWEMBAHgdD8O6hcwyIw2XUI="}}
But the plug is not turning off (or on for that matter)
@K4CZP3R do you know whatā€™s going on?
Thanks :slight_smile:
Your payload needs to be encrypted and inserted as param in payload with method: securePassthrough (Read ā€œfirst secure passthroughā€ in my write up)
Edit: Iā€™ve started to implement it in Python too. Iā€™m having problem with decryption methods (in Java itā€™s way easier because app is written in Java too). And there are so many formats of encoding etcā€¦
Is this just a simple Base64 encode or does it involve another method?
Thanks for all the help :slight_smile:
Itā€™s a encryption using AES.
Ok, Thanks I will try that now :slight_smile:
edit: Whatā€™s the key I should be using? My public and private keys are too long. (Sorry if this is a stupid questionā€¦)
