I must to configure 3 switch Tplink HS100 (that I named “uno”, “due” and “tre”).
If I watch in state, I don’t see ampere, voltage and other parameter, but I see only “friendly name”; there are not other attributes :
My configuration.yaml is this:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
logger:
default: info
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Text to speech
#tts:
# - platform: google_translate
discovery:
tplink:
discovery: false
switch:
- host: 10.10.0.106
- host: 10.10.0.120
- host: 10.10.0.129
switch:
- platform: tplink
host: 10.10.0.106
# Sensors
# Weather prediction
- platform: yr
- platform: time_date
sensors:
my_tp_switch_amps:
friendly_name_template: "{{ states.switch.uno.name}} Current"
value_template: '{{ states.switch.uno.attributes["current_a"] | float }}'
unit_of_measurement: 'A'
my_tp_switch_watts:
friendly_name_template: "{{ states.switch.uno.name}} Current Consumption"
value_template: '{{ states.switch.uno.attributes["current_power_w"] | float }}'
unit_of_measurement: 'W'
my_tp_switch_total_kwh:
friendly_name_template: "{{ states.switch.uno.name}} Total Consumption"
value_template: '{{ states.switch.uno.attributes["total_energy_kwh"] | float }}'
unit_of_measurement: 'kWh'
my_tp_switch_volts:
friendly_name_template: "{{ states.switch.uno.name}} Voltage"
value_template: '{{ states.switch.uno.attributes["voltage"] | float }}'
unit_of_measurement: 'V'
my_tp_switch_today_kwh:
friendly_name_template: "{{ states.switch.uno.name}} Today's Consumption"
value_template: '{{ states.switch.uno.attributes["today_energy_kwh"] | float }}'
input_datetime:
both_date_and_time:
name: Input con data e ora
has_date: true
has_time: true
only_date:
name: Input con solo data
has_date: true
has_time: false
only_time:
name: Input con solo orario
has_date: false
has_time: true
# riferimenti ai 3 file sidecar
group: !include groups.yaml
script: !include scripts.yaml
Why ?
