I have a traccar server running on another host than where home assistant is running - and I can connect to the server via a web browser, and can see, that device tracking works…
However - it does not look like the information goes into home assistant.
Port is correct (I assume, that it is the WebUI port)
Both Home Assistant and the traccar server are VMs running on the same VMware box - and they are in the same IP subnet. So IP connectivity should not be an issue.
I have this in my log - not sure if it is related to the traccar entry:
Updating device list from legacy took longer than the scheduled scan interval 0:00:12
Also, there is this entry:
Logger: homeassistant.components.device_tracker
Source: components/device_tracker/setup.py:88
Integration: Device tracker ([documentation](https://www.home-assistant.io/integrations/device_tracker), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+device_tracker%22))
First occurred: 9:29:56 PM (1 occurrences)
Last logged: 9:29:56 PM
Error setting up platform legacy
I don’t use Teaccar myself but the documentation doesn’t show ‘all_events’ as being valid for monitored_conditions (which is described as being for tracking non-standard attributes), only for event so have you tried it like this?
Hi Bipsen, I have the same problem but I’m not be able to fix it.
could you help me ?
let me explain you better, I installed and cofigured app “traccar” on my android. using https://mio.duckdns.or/api…
this packet passthrough the a router using a nat port forwarding and arriva to fiewrall. this firewall decide to redirect the packet 443 to virtual server inside the lan where is HA e nginx installed.
using terminal HA I can seee that the packet is arrived, but probably somethings go wrong, colud be the configuration of nginx ?
I dropped the traccar tracker - and instead tries to use the tracking via the HA app - with mixed success (tracking is often updated when e.g. using google maps/navigation - but in other scenarios the tracker is only updated every 15 minutes, and for a single device apparently only when in use (all samsung android phones), and this is even when trying to modify the phones not to terminate the application, allow it to run in the background, have access to location etc…
