I m trying to figure out whether or not it is possible to link my hassio to traccar server (not hassio add-on, but traccar server hosted on different server).
Is this something can be done? Or traccar integration can only be done with traccar server addon?
It works fine with any traccar install.
how do you go about it?
I tried adding the following lines in my config.yaml, but doesnt seem to work
device_tracker:
- platform: traccar
host: xxx.xxx.xxx.x
username: [email protected]
password: mypassword
port: 8020
That looks pretty much the same as mine, I’m using TLS however,
device_tracker:
- platform: traccar
username: !secret traccar_username
password: !secret traccar_password
host: traccar.pi.localdomain
port: 443
ssl: true
verify_ssl: false
What errors do you get?
i didn’t get error. but the devices are not discovered.
I supposed it should auto discover my device_tracker as entities upon integration?
This is all i see in the integration page.
You are probably going to need to look at the homeassistant log, otherwise it’s difficult to say.
