Hi, I tried to install the Traccar server but I can’t match the devices because the ports are closed. (the router forwards well, it’s just HA that blocks the traffic!) Scanning I see that only the ports are open
139
445
8123
how can I fix it? Thanks
The-May
(The May)
April 12, 2021, 10:35am
2
I have the same issue.
Did you somehow solve it?
5013 will not be redirected to my Home assistant OS with Traccar Addon enabled.
(Other Ports work flawlessly on other Addons)
The-May
(The May)
May 5, 2021, 8:42pm
3
Found it out…i was not reading the documentation properly.
You need to edit “traccar.xml” in \config (the same folder where your configuration.yaml is)
Otherwise your Traccar port will not be forwarded by the AddOn
In my case i had to open up 5013 by cutting out the line and putting it above:
<?xml version='1.0' encoding='UTF-8'?>
<!DOCTYPE properties SYSTEM 'http://java.sun.com/dtd/properties.dtd'>
<properties>
Loads default configuration for the Hass.io add-on.
WARNING: Do not remove this line!
<entry key='config.default'>/etc/traccar/hassio.xml</entry>
This is the main configuration file. All your configuration parameters should be placed in this file.
Parameters in the main config file override values in the default file. Do not
remove "config.default" parameter from this file unless you know what you are doing.
For list of available parameters see following page:
https://www.traccar.org/configuration-file/
<!-- Enter you custom configuration below this line -->
<entry key='h02.port'>5013</entry>
<!-- // Example ports/protocols you can activate
<entry key='gps103.port'>5001</entry>
<entry key='tk103.port'>5002</entry>
<entry key='gl100.port'>5003</entry>
<entry key='gl200.port'>5004</entry>
<entry key='t55.port'>5005</entry>
<entry key='xexun.port'>5006</entry>
<entry key='xexun.extended'>false</entry>
<entry key='totem.port'>5007</entry>
<entry key='enfora.port'>5008</entry>
<entry key='meiligao.port'>5009</entry>
<entry key='trv.port'>5010</entry>
<entry key='suntech.port'>5011</entry>
<entry key='progress.port'>5012</entry>
<entry key='jt600.port'>5014</entry>
<entry key='huabao.port'>5015</entry>
<entry key='v680.port'>5016</entry>
<entry key='pt502.port'>5017</entry>
<entry key='tr20.port'>5018</entry>
<entry key='navis.port'>5019</entry>
<entry key='meitrack.port'>5020</entry>
<entry key='skypatrol.port'>5021</entry>
<entry key='gt02.port'>5022</entry>
<entry key='gt06.port'>5023</entry>
<entry key='megastek.port'>5024</entry>
<entry key='navigil.port'>5025</entry>
<entry key='gpsgate.port'>5026</entry>
<entry key='teltonika.port'>5027</entry>
<entry key='mta6.port'>5028</entry>
<entry key='tzone.port'>5029</entry>
<entry key='tlt2h.port'>5030</entry>
<entry key='taip.port'>5031</entry>
<entry key='wondex.port'>5032</entry>
<entry key='cellocator.port'>5033</entry>
<entry key='galileo.port'>5034</entry>
<entry key='ywt.port'>5035</entry>
<entry key='tk102.port'>5036</entry>
<entry key='intellitrac.port'>5037</entry>
<entry key='gpsmta.port'>5038</entry>
<entry key='wialon.port'>5039</entry>
<entry key='carscop.port'>5040</entry>
<entry key='apel.port'>5041</entry>
<entry key='manpower.port'>5042</entry>
<entry key='globalsat.port'>5043</entry>
<entry key='atrack.port'>5044</entry>
<entry key='pt3000.port'>5045</entry>
<entry key='ruptela.port'>5046</entry>
<entry key='topflytech.port'>5047</entry>
<entry key='laipac.port'>5048</entry>
<entry key='aplicom.port'>5049</entry>
<entry key='gotop.port'>5050</entry>
<entry key='sanav.port'>5051</entry>
<entry key='gator.port'>5052</entry>
<entry key='noran.port'>5053</entry>
<entry key='m2m.port'>5054</entry>
<entry key='osmand.port'>5055</entry>
<entry key='easytrack.port'>5056</entry>
<entry key='gpsmarker.port'>5057</entry>
<entry key='khd.port'>5058</entry>
<entry key='piligrim.port'>5059</entry>
<entry key='stl060.port'>5060</entry>
<entry key='cartrack.port'>5061</entry>
<entry key='minifinder.port'>5062</entry>
<entry key='haicom.port'>5063</entry>
<entry key='eelink.port'>5064</entry>
<entry key='box.port'>5065</entry>
<entry key='freedom.port'>5066</entry>
<entry key='telic.port'>5067</entry>
<entry key='trackbox.port'>5068</entry>
<entry key='visiontek.port'>5069</entry>
<entry key='orion.port'>5070</entry>
<entry key='riti.port'>5071</entry>
<entry key='ulbotech.port'>5072</entry>
<entry key='tramigo.port'>5073</entry>
<entry key='tr900.port'>5074</entry>
<entry key='ardi01.port'>5075</entry>
<entry key='xt013.port'>5076</entry>
<entry key='autofon.port'>5077</entry>
<entry key='gosafe.port'>5078</entry>
<entry key='tt8850.port'>5079</entry>
<entry key='bce.port'>5080</entry>
<entry key='xirgo.port'>5081</entry>
<entry key='calamp.port'>5082</entry>
<entry key='mtx.port'>5083</entry>
<entry key='tytan.port'>5084</entry>
<entry key='avl301.port'>5085</entry>
<entry key='castel.port'>5086</entry>
<entry key='mxt.port'>5087</entry>
<entry key='cityeasy.port'>5088</entry>
<entry key='aquila.port'>5089</entry>
<entry key='flextrack.port'>5090</entry>
<entry key='blackkite.port'>5091</entry>
<entry key='adm.port'>5092</entry>
<entry key='watch.port'>5093</entry>
<entry key='t800x.port'>5094</entry>
<entry key='upro.port'>5095</entry>
<entry key='auro.port'>5096</entry>
<entry key='disha.port'>5097</entry>
<entry key='thinkrace.port'>5098</entry>
<entry key='pathaway.port'>5099</entry>
<entry key='arnavi.port'>5100</entry>
<entry key='nvs.port'>5101</entry>
<entry key='kenji.port'>5102</entry>
<entry key='astra.port'>5103</entry>
<entry key='homtecs.port'>5104</entry>
<entry key='fox.port'>5105</entry>
<entry key='gnx.port'>5106</entry>
<entry key='arknav.port'>5107</entry>
<entry key='supermate.port'>5108</entry>
<entry key='appello.port'>5109</entry>
<entry key='idpl.port'>5110</entry>
<entry key='huasheng.port'>5111</entry>
<entry key='l100.port'>5112</entry>
<entry key='granit.port'>5113</entry>
<entry key='carcell.port'>5114</entry>
<entry key='obddongle.port'>5115</entry>
<entry key='hunterpro.port'>5116</entry>
<entry key='raveon.port'>5117</entry>
<entry key='cradlepoint.port'>5118</entry>
<entry key='arknavx8.port'>5119</entry>
<entry key='autograde.port'>5120</entry>
<entry key='oigo.port'>5121</entry>
<entry key='jpkorjar.port'>5122</entry>
<entry key='cguard.port'>5123</entry>
<entry key='fifotrack.port'>5124</entry>
<entry key='smokey.port'>5125</entry>
<entry key='extremtrac.port'>5126</entry>
<entry key='trakmate.port'>5127</entry>
<entry key='at2000.port'>5128</entry>
<entry key='maestro.port'>5129</entry>
<entry key='ais.port'>5130</entry>
<entry key='gt30.port'>5131</entry>
<entry key='tmg.port'>5132</entry>
<entry key='pretrace.port'>5133</entry>
<entry key='pricol.port'>5134</entry>
<entry key='siwi.port'>5135</entry>
<entry key='starlink.port'>5136</entry>
<entry key='dmt.port'>5137</entry>
<entry key='xt2400.port'>5138</entry>
<entry key='dmthttp.port'>5139</entry>
<entry key='alematics.port'>5140</entry>
<entry key='gps056.port'>5141</entry>
<entry key='flexcomm.port'>5142</entry>
<entry key='vt200.port'>5143</entry>
<entry key='owntracks.port'>5144</entry>
<entry key='vtfms.port'>5145</entry>
<entry key='tlv.port'>5146</entry>
<entry key='esky.port'>5147</entry>
<entry key='genx.port'>5148</entry>
<entry key='flespi.port'>5149</entry>
<entry key='dway.port'>5150</entry>
<entry key='recoda.port'>5151</entry>
<entry key='oko.port'>5152</entry>
<entry key='ivt401.port'>5153</entry>
<entry key='sigfox.port'>5154</entry>
<entry key='t57.port'>5155</entry>
<entry key='spot.port'>5156</entry>
<entry key='m2c.port'>5157</entry>
<entry key='austinnb.port'>5158</entry>
<entry key='opengts.port'>5159</entry>
<entry key='cautela.port'>5160</entry>
<entry key='continental.port'>5161</entry>
<entry key='egts.port'>5162</entry>
<entry key='robotrack.port'>5163</entry>
<entry key='pt60.port'>5164</entry>
<entry key='telemax.port'>5165</entry>
<entry key='sabertek.port'>5166</entry>
<entry key='retranslator.port'>5167</entry>
<entry key='svias.port'>5168</entry>
<entry key='eseal.port'>5169</entry>
<entry key='freematics.port'>5170</entry>
<entry key='avema.port'>5171</entry>
<entry key='autotrack.port'>5172</entry>
<entry key='tek.port'>5173</entry>
<entry key='wristband.port'>5174</entry>
<entry key='applet.port'>5175</entry>
<entry key='milesmate.port'>5176</entry>
<entry key='anytrek.port'>5177</entry>
<entry key='smartsole.port'>5178</entry>
<entry key='its.port'>5179</entry>
<entry key='xrb28.port'>5180</entry>
<entry key='c2stek.port'>5181</entry>
</properties>
