I am fairly new to Home Assistant. It has been about 3 weeks since I switched from SmartThings. I am really loving how much better it works.
I installed using a Raspberry Pi 4 using the image downloaded from the website. I have version 0.115.3 installed.
I installed Traccar using the Supervisor addon and have it working on it’s own very well. I installed an ST-902 GPS device in my car and it communicates well with the Traccar server.
My problem is that I cannot get the HA integration to work. There is no mention of Traccar in the HA core logs. I have tried the following:
I have also tried changing the port to 8072, which is the port I use for the web access. I have also tried changing the host to the localhost, local hostname, and local IP. Nothing seems to work.
I didn’t create any devices in HA. I assumed the integration automatically created them. Is that what I am missing? Do I need to manually create them? If so, how do I do that?
Yes, I have one device in Traccar being tracked so far. It is green and showing online.
