Hi All,
I recently started using blueprints for several things i had build in NodeRed. Most of them were straight forward and working. The last one i’m having a bit of trouble with is the mobile alert when nobody is home.
What happens:
Were are both at work so nobody is home. When one of the door sensors gets triggered i want a push notification on my mobile phone.
To me this looks fine but somehow the flow says it’s false and stops.
Please try changing the conditions to this.
condition:
- condition: and
conditions:
- condition: state
entity_id: device_tracker.iphone_van_maurice
state: not_home
- condition: state
entity_id: device_tracker.iphone_van_yvette
state: not_home
I can’t edit it.
This is just how the dropdown menu gave me the options within the automation.
I can select “iPhone is home” or “iPhone is not home” and a bunch of other options.
Instead of blueprints you can build an automation. I can help you with that.It should look like this.
alias: Door and Window Monitor
mode: queued
- platform: state
entity_id:
- binary_sensor.window1
- binary_sensor.door1
condition:
- condition: and
conditions:
- condition: state
state: not_home
- condition: state
state: not_home
- service: notify.telegram_carlton
title: Alert
message: >-
The {{ trigger.to_state.name }} was {{ 'opened' if
trigger.to_state.state == 'on' else 'closed' }}
max: 10
Just change the entity ids and service to your system.
You can copy the automation like this.
