Traceback error installing 37.0
I’m not able to upgrade my 36.1 to 37.0 because of this error. What have I done wrong???
Exception:
  File "/usr/lib/python3.4/shutil.py", line 522, in move
    os.rename(src, real_dst)
PermissionError: [Errno 13] Permission denied: '/usr/lib/python3/dist-packages/Jinja2-2.7.3.egg-info' -> '/tmp/pip-ljd1gqws-uninstall/usr/lib/python3/dist-packages/Jinja2-2.7.3.egg-info'
  File "/usr/local/lib/python3.4/dist-packages/pip/basecommand.py", line 215, in main
    status = self.run(options, args)
  File "/usr/local/lib/python3.4/dist-packages/pip/commands/install.py", line 342, in run
    prefix=options.prefix_path,
  File "/usr/local/lib/python3.4/dist-packages/pip/req/req_set.py", line 778, in install
    requirement.uninstall(auto_confirm=True)
  File "/usr/local/lib/python3.4/dist-packages/pip/req/req_install.py", line 754, in uninstall
    paths_to_remove.remove(auto_confirm)
  File "/usr/local/lib/python3.4/dist-packages/pip/req/req_uninstall.py", line 115, in remove
    renames(path, new_path)
  File "/usr/local/lib/python3.4/dist-packages/pip/utils/__init__.py", line 267, in renames
    shutil.move(old, new)
  File "/usr/lib/python3.4/shutil.py", line 532, in move
    rmtree(src)
  File "/usr/lib/python3.4/shutil.py", line 463, in rmtree
    _rmtree_safe_fd(fd, path, onerror)
  File "/usr/lib/python3.4/shutil.py", line 421, in _rmtree_safe_fd
    onerror(os.unlink, fullname, sys.exc_info())
  File "/usr/lib/python3.4/shutil.py", line 419, in _rmtree_safe_fd
    os.unlink(name, dir_fd=topfd)
PermissionError: [Errno 13] Permission denied: 'not-zip-safe'
If you used a different user for your installation you need to use that user for the update.
I installed the All In One script on a fresh Raspbian Jessie from user Pi, however, I have been using these commands to upgrade previously and they have worked for me.
sudo su -s /bin/bash homeassistant
source /srv/homeassistant/homeassistant_venv/bin/activate
pip3 install --upgrade homeassistant
Not sure what’s different this time. I went ahead and tried the fabric upgrade method and it worked. I’ll switch to that method from now on!
