Traceback errors on all devices
Installing any config changes on either of my devices, I get the below tracebacks. Rebooted host, latest updates installed. Even installed ESPHome update this morning and still get them. Devices appear to be functioning normally and take updates.
  File "/usr/local/bin/esphome", line 33, in <module>
    sys.exit(load_entry_point('esphome', 'console_scripts', 'esphome')())
  File "/esphome/esphome/__main__.py", line 955, in main
    return run_esphome(sys.argv)
  File "/esphome/esphome/__main__.py", line 942, in run_esphome
    rc = POST_CONFIG_ACTIONS[args.command](args, config)
  File "/esphome/esphome/__main__.py", line 390, in command_logs
    return show_logs(config, args, port)
  File "/esphome/esphome/__main__.py", line 310, in show_logs
    from esphome.components.api.client import run_logs
  File "/esphome/esphome/components/api/client.py", line 6, in <module>
    from aioesphomeapi import APIClient, ReconnectLogic, APIConnectionError, LogLevel
  File "/usr/local/lib/python3.9/dist-packages/aioesphomeapi/__init__.py", line 3, in <module>
    from .client import APIClient
  File "/usr/local/lib/python3.9/dist-packages/aioesphomeapi/client.py", line 21, in <module>
    from .api_pb2 import (  # type: ignore
  File "/usr/local/lib/python3.9/dist-packages/aioesphomeapi/api_pb2.py", line 7, in <module>
    from google.protobuf import descriptor as _descriptor
  File "/usr/local/lib/python3.9/dist-packages/google/protobuf/descriptor.py", line 47, in <module>
    from google.protobuf.pyext import _message
ImportError: /usr/local/lib/python3.9/dist-packages/google/protobuf/pyext/_message.cpython-39-x86_64-linux-gnu.so: undefined symbol: _ZN6google8protobuf2io26CopyingOutputStreamAdaptorC2EPNS1_1\udcac3
