I’m wondering why my code is not working. I did it like that for the state because I got other zones as well like work and I just want to know how long I was not at home.
- platform: history_stats
name: Sascha - Zeit in Abwesenheit
entity_id: person.cptdaydreamer
state: "{{ 'home' not in states('person.cptdaydreamer') }}"
type: time
start: "{{ now().replace(hour=0, minute=0, second=0, microsecond=0) }}"
end: "{{ now() }}"
For presence it works well:
name: Sascha - Zeit zu Hause
state: "home"
type: time
end: "{{ now() }}"
What? I already got this kind of sensor as you can see. I want the opposite and the problem is that I have multiple zones so I cannot say state: not_home
What Petro says is that you cannot use a template in the state: (even if you could, your template is just returning a boolean, anyway).
You could use a list, though, so you could just enumerate the zones which are not “home”, although it’s not great for maintainability, so just use Petro’s idea.
Keep your “Time at home” history stats sensor. Then create a template sensor using the template I provided above, just make sure you update the entity_id in the template to use your “time at home” sensor.
Keep in mind that history stats and template sensors are separate integrations, so they will not go in the same spot in your configuration.yaml.
I would assume so. I don’t know what units your sensor is in. If you want the values to be numerical, add device_class: duration and unit_of_measurement: s.
Still not able to get what I want because I want it like this:
But instead of 0,0 hours, I want the value. Damn programming in Java and Python is easy. This here is really tricky.
