i´m quite new to hass.io.
used the search already but couldn´t find what i need.
can i track my iphone on the map?
i set up “device_tracker: - platform: icloud” already, however i have no clue how to show it on the map.
also, the “sensor.iphone_battery_level” shows the wrong batterylevel, how can i fix that?
is there any more information i could get from my phone to show on hass.io?
Do you see a device in the developer section under states in line with device_tracker.xxxx? if so good, if not, then have a look on your setup.
Note that devices will not show up on the map when home.
@Piggyback
i see “device_tracker.iphone” and it shows the name i set in “known_devices.yaml”.
so when i connect to my hass.io from work it should show my phone?
