Track light recommendation
Hi, so we have renovation going and my wife wants track light installed in the bedroom.
IMG_2956
I’ve been browsing alibaba but it looks like most of these lights use zigbee or bluetooth.
Saw this question posted in the github but doesn’t look like z2m has support for it
Does anyone know if there is wifi version or if the zigbee track light can easily be tear down so I could just swap the zigbee chip with esp?
What kind of LED strip does it have?
You could look into WLED or use a Shelly RGBW2.
It’s using led strip with either of these chips listed below
https://solution.tuya.com/projects/CMayfllf6nyf4u
More details on track light here
I already have plan to install led strip in other parts of the room, but we’re going with track lights for the ceiling
Hi! Did You found the solution for the track light? I plan to purchase the same if i can integrete in HA.
The ones you can find on aliexpress is supported since they’re all using the same driver in z2m
Anyway, there’s a new matter over thread version that came out after i bought the zigbee and the price is pretty much the same
http://e.tb.cn/h.T1ngbwQ7OhiphPr?tk=uTSR3H19Wwe
I bought one for a test. It seems be very laggy for example when change temperature white.
It’s even stuck for a while and lose connection form zigbee network.
Do you have similar issues?
