I’ve seen a lot of the videos for blinds, shades and curtains.
Roller shades, vertical blinds, curtains.
But I haven’t seen anyone anywhere post anything about track panel blinds?
I was thinking of trying something w/ esp8266 but not sure what other components to need to drive to pull the track across?
You could probably use a small DC motor attached to a string that gets wound up on either side, and have an endswitch that gets pressed when the last panel hits the end position.
If you don’t want a DIY solution you could use sth. like this maybe? https://templates.blakadder.com/zemismart_YH002.html
I’ve never done an esp project before and have 2 littles so gonna see if I can manage to try one.
I think this ‘should’ be easy since the blinds are already on a fixed track and dont weight much.
Just surprised no ones posted anything on it anywhere.
I just did a GaragePi implementation and moved so trying to pick up some more projects. But trying to plan it out since hard w/ the littles in my way all the time and not keen and any more trips to HD.
