My devices not longer show up individually as home or away in the Overview after this upgrade. I also added the tile integration and can’t see these devices in the Overview.
What happened? How can I get back the old behaviour?
Did you check the release notes?
We no longer show
device_tracker
entities in generated mode. We advise you to bind one or more device trackers to a person that will be shown in the UI.
Can you help me understand that line, i re-read it and still not get it.
I have setup this in my config
device_tracker:
- platform: mikrotik
host: 192.168.1.1
username: ***
password: ***
interval_seconds: 60
consider_home: 0:03:00
new_device_defaults:
track_new_devices: false
and i am getting
The following integrations and platforms could not be set up:
device_tracker
Please check your config.
If the device tracker was there before - then it should still exist, just not be shown on the generated view. To get similar functionality as you had before (and it potentially enables better functionality in the future):
Also, I don’t use MikroTik, but that’s changed too. It would probably be best to set it up from the UI.
MikroTik - MikroTik Integration can now be added from the integrations UI! It also supports importing existing configurations from configuration.yaml
(refer to the docs to update your configuration). Now uses the entity registry for managing devices ( known_devices.yaml
will not be used anymore), this causes devices to be re-discovered. - (@engrbm87 - #27484) (mikrotik docs)
I did read the release notes. I guess I was too busy fixing my August and NetAtmo integrations to notice the details.
It would be nice if there was a way to keep the current behaviour (I already excluded the devices I don’t want tracked).
