Hi!
Right now i have Unifi tracker (For not family) and iCloud for Family.
And i use Pushover for notify.
Today i have 1 rule for every Family/not family when home/ not home.
Could I in any way make 1 rule, for who ever enter/ leave home?
Hi!
I think you need to be a bit more specific with your problem. I fail to grasp what you are trying to achieve / want to happen.
~Cheers
Are you asking if you can do an all encompassing automation for different trackers? if so, then yes.
Just use an OR condition
Allright, what i mean is that today i have one automation for every person in the home.
like this:
- alias: āRule 014 - Notify me Away Sussā
hide_entity: True
platform: state
entity_id:
- device_tracker.susanne
to: ānot_homeā
service: notify.iphone7
message: āSuss left homeā
But what I would like to have is 1 automation for everyone.
Iām interested in how to implement this too.
Iām having welcome sound automations (17 at the moment) for certain people which play over my Chromecasts when they connect to my wifi network. I have 17 seperate automations for this and everytime I want to add someone I have to create a new automation. I know there must be a way to combine them all in 1 automation but havenāt succeeded yet.
This is what I have now (17 automations like this):
- alias: 'Welcome xxxxxx'
platform: state
entity_id: device_tracker.xxxxxx
to: 'home'
- service: media_player.volume_set
entity_id: media_player.home_group
volume_level: '0.65'
- service: media_player.play_media
media_content_id: <<DIRECT MP3 LINK>>
media_content_type: 'audio/mp3'
Iām just spitballing here because Iām barely 2 weeks into my HA build but is it possible to use a group as the entity id?
Multiple ways actually to handle this. Easiest would be to donāt do full blown automations just add multiple trigger to your automation like so:
- alias: 'Welcome People'
- platform: state
to: 'home'
- platform: state
entity_id: device_tracker.yyy
to: 'home'
Other solutions include using template conditions and you declaring a array of people that should be notified. Itās a little less work to add someone new but would require more tinkering than just multiple triggers
~Cheers
You would use the same thing I explained one post above but additionally you would use a ādata_templateā for your notify service like this:
data_template:
message: '{{ trigger.to_state.attributes.friendly_name}} just left home'
~Cheers
@PhyberApex thanks for your reply, I understand the multiple trigger part. But for the play mp3 part I probably need to use an If/Else template. My problem is that I donāt know where to compare the device tracker IDās with.
This is what I have came up with, missing some crucial parts.
- platform: state
to: 'home'
- platform: state
to: 'home'
data_template:
media_content_id: >
{% if is_state("what do I need to put here?", "device_tracker.xxx") %} <DIRECT LINK TO MP3 1>
{% elif is_state("what do I need to put here?", "device_tracker.yyy") %} <DIRECT LINK TO MP3 2>
{% endif %}
You are nearly there. If you look here you can see what is available to you from the triggered entity that triggered this automation: https://home-assistant.io/docs/automation/templating/#available-trigger-data
So maybe this is what you want?
media_content_id: >
{% if trigger.entity_id == "device_tracker.xxx" %} <DIRECT LINK TO MP3 1>
{% elif trigger.entity_id == "device_tracker.yyy" %} <DIRECT LINK TO MP3 2>
{% endif %}
~Cheers
Wow, did not find that page earlier. This is the key to a lot of new ideas. Thanks man!
