That’s awesome, thanks for posting! I may try this on my wall tablet, I like following a medflight helicopter that flies over my house from a local airport.
Very nice, I have something that combines me manually typing in the callsign, then opensky finds the icao24 based on that with which opensky (othe endpoint) can track in realtime, showing it on a map…but the whole is unreliable as opensky is … an dhaving to go multiple steps to find a plane is less nice too
Few months ago I searched a lot for another solution…and now I seem to have one…thanks!
I am making progress replacing the opensky one, this adsb is soo much more repsonsive…really like it.
However… as most the providers in the area are limiting api calls, is there any foreseeable risk this becomes restricted/paid? @UngluedChalice I am using a command_line sensor that loads data based on the callsign that I manually type in (input-text helper). You can automate a refresh of that sensor based on a date…I would base it on a calendar entry
Wanted to add my current (not very fancy looking) trickeries with this solution
In fact, I created a few command_line sensors and with ‘jq’ I get the data out in a format that allows me to use it further in HA. The refresh button makes it easy to refersh if I cannto wait for the 10mins refresh cycle
2024-03-09 08:24:43.511 ERROR (MainThread) [custom_components.flightradar24] FlightRadar24: No flight found by number - F-HXKI
2024-03-09 08:25:36.055 ERROR (MainThread) [custom_components.flightradar24] FlightRadar24: No flight found by number - 39dd48
2024-03-09 08:25:59.908 ERROR (MainThread) [custom_components.flightradar24] FlightRadar24: No flight found by number - MICKY
2024-03-09 08:26:38.040 ERROR (MainThread) [custom_components.flightradar24] FlightRadar24: No flight found by number - OE-LKK
And I have now improved the flights around a self-chosen person/zone. The removal of old flights was not working fine… and it tracks the flights now along the refresh frequency
