The CDC is now publishing amount of COVID in wastewater in the US.
I decided to create a simple tracker for this.
Here’s what I did (using Seattle’s data as an example - you can find the right query in the CDC’s Data Explorer
- platform: command_line
name: "COVID WasteWater"
scan_interval: 86400
command: >
echo "{ \"data\":" $(
curl -s https://data.cdc.gov/resource/g653-rqe2.json?key_plot_id=CDC_BIOBOT_wa_1139_Treatment%20plant_raw%20wastewater
value_template: >
{{ value_json.data | length }}
json_attributes:
- data
and then I used the really nice Apex Charts Card
like so:
type: custom:apexcharts-card
header:
title: King County COVID Wastewater
show: true
colorize_states: true
graph_span: 90d
chart_type: scatter
series:
- entity: sensor.covid_wastewater
data_generator: |
var filtered_data = entity.attributes.data.filter(function(record) {
return 'pcr_conc_smoothed' in record;
var filtered_map = filtered_data.map(record => {
return [new Date(record.date).getTime(), record.pcr_conc_smoothed/1000000];
return filtered_map;
End result:
